Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Adjusting tailgate on 2009 Escape
Old 10-03-2012, 11:10 AM
JohnnyThunder's Avatar
JohnnyThunder
JohnnyThunder is offline
We live in the country and my 09 Escape has developed a slightly loose tailgate or rear door if you will and as such I am getting alot of dust coming in around the tailgate. You can see that is is not sealing about 2/3 of the way around. I cannot seem to find how to adjust the pin that the latch catches as the latch in the tailgate is non adjustable it seems.
Thanks for anyone that can help.
Old 10-03-2012, 04:25 PM
Torky2's Avatar
Torky2
Torky2 is offline
Ours isn't here now so I can't simply go and look at it. But many Ford Cars and trucks over the years have had door/tailgate/hatch striker bolts that were adjustable. The striker bolts have a Torx-sized recess in the end of them. Loosened with a proper-sized Torx bit on a ratchet, they could be slid around for adjustment. Inside the body panel was a captive plate with an integral nut that the striker bolt threads into.
I always wash and dry the area around a striker bolt to get it clean, and then apply some masking tape to outline the striker bolt's washer, or use a Sharpie marker to do the same, as it is easy to go astray without having the original setting for reference.
The manual says to remove the scuff plate first, and the Striker Bolt Torque is 30 Ft. Lbs.
Old 10-04-2012, 07:24 AM
JohnnyThunder
Thanks for the info, I'll give it a go after work today.
blue351
11-27-2018 05:20 AM
yargnitram
07-28-2018 10:07 AM
alchemist1
06-20-2015 06:14 PM
tomfrey
1997 - 2003 F150
03-29-2015 12:50 AM
Big Red Stroker
04-17-2005 11:55 AM
Quick Reply: Adjusting tailgate on 2009 Escape
