1970 9" disc brake conversion help...
Old May 24, 2011 | 11:56 PM
85e150's Avatar
85e150
Originally Posted by Alcaeus
Why not use the 78 rotors with the hardware from a 9" car axle and stay all ford?
See post 1.
Old Jun 16, 2012 | 05:20 PM
SFD76's Avatar
SFD76
new to the forum
75F350 are you grinding off the cup on the caliper bracket? I did the chevy spindles on the front of my 76 bronco Dana 44. I have another set of brackets off of a 77 chevy and it has a cup on it....second question is if you had a good way of making sure the bracket is centered before you drill the Big Ford bolt pattern into the bracket?
Thanks for any help....
Old Jun 17, 2012 | 05:22 PM
SFD76's Avatar
SFD76
Did a google search and found your photobucket pictures got questions answered thanks....
Old Dec 8, 2018 | 08:54 AM
Rmeeks's Avatar
Rmeeks
Hello everyone, brand new member here. I have a completely stock 1970 2WD F250. I would like to complete a disc brake conversion on the front and rear. Is it better to keep the axles and buy the parts or get a junkyard axle with disc brake setup?
Old Dec 8, 2018 | 03:59 PM
85e150's Avatar
85e150
Welcome to FTE.
Feel free to start your own thread on this. I think you probably have a Dana 60 axle, but you should confirm that first. You would not have a 9 inch in an F250, so any solution in this thread is not applicable to your truck.
IMO a front disc swap is well worth the effort. On a stock truck, the rear disc swap is a marginal effort. The complications, odd ball parts, and parking brake issues overcome the marginal increment in braking. Well done properly adjusted rear drums with quality parts provide ample braking for most circumstances.
Old Dec 9, 2018 | 04:16 PM
Rmeeks's Avatar
Rmeeks
Ill grab some info from my truck and create a thread.
Old May 11, 2019 | 11:01 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Just to subscribe to this thread so can find it later.
Goofy1129
18
Jul 30, 2016 02:01 AM
Big_Red_Brute
Nov 4, 2014 06:11 PM
SuperDuty93
Dec 14, 2013 08:30 PM
dthomas620
16
Mar 15, 2012 04:49 PM
daveaprile
Jul 16, 2011 12:15 PM
