help...
Old Apr 30, 2009 | 06:21 PM
hoss95's Avatar
hoss95
Exclamation help...
ok im new here first ford ive owned and diesel but anyways i have a 1995 f250 7.3 powerstroke 5 speed runs drives good well couple days ago at idle i looked at my dash and my battery light was blinkin and my voltage meter was jumpin alittle but when i get goin it stops and meter levels out??? and another thing i descovered today is when im idleing and turn my radio up loud or turn my heat or ac on or use a window the battery light stops flashing but when i turn all of them off and the truck is just idleing it starts flashing again the batteries r new i made sure the cables was tight and they r it starts up fast no hard starts even in cold so what could this possibly be? please help thanks
Old Apr 30, 2009 | 06:35 PM
yoslick's Avatar
yoslick
I'd get a load tester and see what your alternators putting out, you may wanna check the wires goin into the alternator as well, they have a habit of gettin pulled out/bent over from workin on the fuel system.....
Old Apr 30, 2009 | 06:59 PM
hoss95's Avatar
hoss95
how many volts should it be putting out?
Old Apr 30, 2009 | 07:07 PM
Hussler's Avatar
Hussler
At idle about 14 plus volts with known good battery's. Bet one of the two new battery's is bad or defective. Take them out and have each load tested where you purchased them or an independent dealer. How long have you had the new battery's and what CCA rating are they? Also brand?
Old Apr 30, 2009 | 10:06 PM
hoss95's Avatar
hoss95
i have no clue they just put them in when i bought it i think their superflex or something like that ive had the truck 2 weeks and it just start yesterday but it wont do it when u first drive it u have to drive about 10-15 miles b4 it will flash at idle it does fine when u first get in and drive at idle no flashin but after alittle drivin it will start...
Old May 3, 2009 | 07:26 PM
hoss95's Avatar
hoss95
ok went today and got my batteries and alt checked and it was all good so why does my battery light keep flickerin im bout to take the bulb out lol
Old May 3, 2009 | 11:10 PM
sbxworship's Avatar
sbxworship
the harness on top of the alternator is notorious for being loose and causing the battery light to come on intermittently. some have had luck with cramming something (like a piece of cardboard) in beside the harness to hold it still and get a good connection. it sounds like that's your problem to me...
Old May 4, 2009 | 04:48 AM
hoss95's Avatar
hoss95
ight ill check that today and get back at yall
Old May 4, 2009 | 11:20 AM
IDMooseMan's Avatar
IDMooseMan
I agree with all that's been said, but based on the responses, I think everyone is assuming your belt is not slipping. Is it in good condition, too? If it is, I'm leaning towards the alternator connection like previously suggested.
Old May 5, 2009 | 02:26 PM
cowmilker08's Avatar
cowmilker08
Do you get it cleared up hoss95?
scottscott
Dec 5, 2020 02:26 PM
Inthswamp
Dec 24, 2016 01:55 PM
dougal3434
Feb 21, 2016 01:25 PM
BUZZARD9311
Dec 11, 2010 07:15 PM
crothenberger
Aug 23, 2003 11:10 PM
