Foil Delete Mod...
Old Apr 30, 2009 | 03:45 PM
Powerstroke-7.3's Avatar
Powerstroke-7.3
Foil Delete Mod...
What exactly is this mod?? I was hoping I could find some pictures on it but I couldn't. Please shine some light on this. Thanks
Old Apr 30, 2009 | 03:48 PM
Red Monkey's Avatar
Red Monkey
You just take the insulation, 'foil', off of your drivers side pipe from the turbo to the IC. That's all there is to it.
Old Apr 30, 2009 | 03:50 PM
Ponyboychris's Avatar
Ponyboychris
If you have a late '99 to 2003 engine, the driver's side IC pipe (next to the intake tube) will have foil on it. You can remove for cleaner look and a little louder turbo whistle. Here's an after pic of mine.
Old Apr 30, 2009 | 03:51 PM
HKusp's Avatar
HKusp
Check the link in my signature, then go to the list of mods, it will be there with a description and some threads with pics.
Old Apr 30, 2009 | 03:56 PM
HKusp's Avatar
HKusp
https://www.ford-trucks.com/forums/forum31/
https://www.ford-trucks.com/forums/4...ml#post3657312
Old Apr 30, 2009 | 06:33 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
here's mine
Old Apr 30, 2009 | 08:12 PM
Izzy351's Avatar
Izzy351
Go to Lowes and get a jug of Crown Sol-U-Strip adhesive remover. The thick stuff. Peel the foil (being careful of the SHARP edges), and just paint on the adhesive remover keeping it wet for about 30 mins. After that, start wiping with shop towels and it should mostly melt right off. Re-apply to more stubborn spots or use a wire brush to help it along. Then finish off with steel wool or SOS pad. Here's what mine looks like:
And here is the thread I started on this a couple years back:
https://www.ford-trucks.com/forums/5...nsulation.html
Old Apr 30, 2009 | 08:17 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is my foil delete. Makes my engine look so much better.
Old Apr 30, 2009 | 08:23 PM
Izzy351's Avatar
Izzy351
Dangit...... Rick had to go & bust out the shiny pic...
Here's mine all purdied up. Need to get a new one though. Mine looks a lot different under there now.
Old Apr 30, 2009 | 08:39 PM
hgoody77's Avatar
hgoody77
ha, i just did this last night, man that little bit of foil is sure on there good. lol
i stripped the foil and then used paint stripper on the foam that was left. then sprayed with pressure washer and it came right off.
Old Apr 30, 2009 | 09:05 PM
00Dave's Avatar
00Dave
Huh, pressure washer, great idea. I've been putting this idea off do to time constraints, but if the pressure washer will take it off I'm in. Well, after I get the new seats in of course!
Old Apr 30, 2009 | 09:06 PM
miller_feed
Joe, yours is looking so good now. If you get yours shinny like mine, you may just have a better looking engine then me.
I do see a little yeller on the spider.
Old Apr 30, 2009 | 09:11 PM
hgoody77's Avatar
hgoody77
Plus look at all that overspray on the top of the battery from the terminal coating. geeeee.
Old Apr 30, 2009 | 09:14 PM
hgoody77's Avatar
hgoody77
Don't forget i also used paint stripper in an aerosal can. let sit and then pressure washed, took maybe 45 minutes to get this all done. to get the foil off i peeled it back some then took pliars and started to roll it up. seemed to work pretty good.
Izzy351's Avatar
Izzy351
That's gone now :
That's gone too (no pic, though).
