up pipes
Old Apr 30, 2009 | 11:33 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Originally Posted by Bossman7121
Hey Clay,
Times ticking for us both. I'm doing these July 4th weekend or so. PM if you get them sooner?
I should have my testing complete in 3 weeks. With the coating that we are going to be testing we are told it will lower temps by at least 55%. Once we get numbers and such we will be able to know if it is what we expect. By retaining heat it will help keep the engine bay temps down and keep the turbo spooled up.
Old May 1, 2009 | 07:49 AM
F250_'s Avatar
F250_
Clay, when you say "lower temps by 55%", correct me if I'm wrong, but I think what you're referring to us that "temperatures around the outside of the upipes being 55% cooler due to reduced radiant heat losses"...????
I can see that being the case because the benefit of reduced radiant heat losses will be two things that are interdependant...
1) higher exhaust temps hitting the exhaust wheel (but that is a good thing because...)
2) faster spooling of the turbo because of #1.... higher gas temps hitting the wheel means a higher volume of gas hitting the wheel, which in turn (literally) means higher gas velocities hitting the wheel... i.e. more wheel spin at any and all engine rpms.
Am I thinking about this right, Clay?
Old May 1, 2009 | 09:37 AM
kccatpower's Avatar
kccatpower
not to high jack the thread but i have a question on up pipes, i have seen the bellowed style ih design and the ones that use braided flex section i believe di has these, is there any difference between the two or pros and cons, thank you.
Old May 1, 2009 | 11:34 AM
Riffraff Diesel
PREMIUM SPONSOR
Yep, you are thinking about it correctly. Basically the heat is energy to turn the drive wheel and the less you lose the better. I will slowly be testing the effects of ceramic coating the manifolds, up-pipes, turbo exhaust housing and down-pipe to see how it helps.
Old May 1, 2009 | 11:35 AM
Riffraff Diesel
PREMIUM SPONSOR
IMO, I can't really see a difference. I have thought about trying to manufacture a style like DI's but at a more competitive price.
Old May 1, 2009 | 11:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
WOW, Who is the lucky Beta tester.
Old May 1, 2009 | 11:38 AM
Riffraff Diesel
PREMIUM SPONSOR
Hmmm, maybe we can have a member in good standing assist
Old May 1, 2009 | 01:52 PM
Bossman7121's Avatar
Bossman7121
come on man... not fair. Must it be good standing ? Serious about it if the timing is right...
I'll also take pictures.... lol
Studawg
Sep 27, 2011 02:06 PM
nolan62
13
Feb 27, 2011 09:40 AM
Welk49
Jan 27, 2010 08:33 PM
jt371
21
Apr 15, 2009 07:32 PM
davidson915
Jan 28, 2008 10:43 AM
