1987 ranger
Old May 12, 2009 | 08:19 PM
  #46
zdewald's Avatar
zdewald
yes i know. could it just be the computer going?? i all ready did that and cant find anything
Old May 12, 2009 | 08:24 PM
  #47
zdewald's Avatar
zdewald
Old May 12, 2009 | 08:29 PM
  #48
Lead Head's Avatar
Lead Head
Usually computers are work/don't work. No real in between state. I'd just hate to see you drop money on a computer and have it not be the problem, see if you can also pull the computer out of that ranger.
Old May 12, 2009 | 08:34 PM
  #49
zdewald's Avatar
zdewald
im hopeing i can get the truck cheap from him because he wraped it around a tree and i was in bad shape before that
Old May 14, 2009 | 03:05 PM
  #50
zdewald's Avatar
zdewald
ok i think i got it. when i start it in gear it reves up like that. but if it is in nutral i dont do it. i beleve this is what is makeing it do it
Old May 14, 2009 | 03:50 PM
  #51
Lead Head's Avatar
Lead Head
As far as I know , at least my ranger doesn't have a neutral safety switch. I suppose your clutch may be dragging a bit, causing it make the engine work a bit harder to get the transmission upto speed. Have you had trouble shifting lately?
Old May 14, 2009 | 04:25 PM
  #52
zdewald's Avatar
zdewald
i still have to push the clutch in even if it is in neutral. i think i do get a code if it is in gear.
Old May 14, 2009 | 04:28 PM
  #53
Lead Head's Avatar
Lead Head
I'm saying your clutch may not be fully releasing - which is why I asked if you have been having some difficulty going into some gears , usually down shifting.
Old May 14, 2009 | 04:42 PM
  #54
zdewald's Avatar
zdewald
nope it shifs just fine. the clutch is new about 6000 miles ago
i just scanned it and when i put it in gear i get 67 o
Old May 14, 2009 | 05:18 PM
  #55
Lead Head's Avatar
Lead Head
67 o is neutral safety circuit failure. Maybe your neutral safety switch has failed?
Old May 14, 2009 | 05:51 PM
  #56
zdewald's Avatar
zdewald
would that make it rev up?
Old May 14, 2009 | 05:52 PM
  #57
zdewald's Avatar
zdewald
i have to push the clutch in if it is in neutral or in gear is that how it should be ??
Old May 14, 2009 | 06:19 PM
  #58
Lead Head's Avatar
Lead Head
i honestly have no idea. My 87 Ranger 2.9 w/5 spd starts the same whether it is in neutral or in gear. Then again my idle valve is not the best.
Old May 14, 2009 | 07:14 PM
  #59
zdewald's Avatar
zdewald
i know. do you have to push the clutch in every time to start it?
Old May 14, 2009 | 07:20 PM
  #60
zdewald's Avatar
zdewald
do you have to push the clutch in to start it??
