94 explorer bad piston ring
Old Apr 29, 2009 | 10:19 PM
AC94EXPLORER's Avatar
AC94EXPLORER
i was wondering how can a ring go bad on a piston? i guess it was causing me to loose water and the spark plug will go bad too. we thought it was a cracked head. anyways i thought i ask
Old Apr 30, 2009 | 08:03 AM
ErnieX's Avatar
ErnieX
How DOES a bad ring cause loss of coolant? Just curious...
Old Apr 30, 2009 | 10:17 AM
AC94EXPLORER
i took it in thinking it has a cracked head cause it was loosing water and the plug was fauling out. i was told over the phone it was a bad piston ring which was weird cause im loosing water and that one plug had that bubble look whern u took it out. anyway i'll keep you up to date when i call later on today to see how it is.
Old Apr 30, 2009 | 11:55 AM
AC94EXPLORER
they are replacing the injectors too it was running very lean.
Old Apr 30, 2009 | 12:55 PM
MisterCMK's Avatar
MisterCMK
A bad ring isn't going to cause you to lose coolant. Did the truck overheat? The OHV 4.0 is very prone to cracked heads if it overheats.
Old Apr 30, 2009 | 02:56 PM
edgewound's Avatar
edgewound
A leaky head gasket can lose coolant....and a sweet smell in the exhaust as well as some extra steam. Coolant for the rings is not good.
Old Apr 30, 2009 | 09:45 PM
AC94EXPLORER
well looks like its gonna be ready by tomorrow im gonna drive it down to california with me to move all my stuff down. this would be my 3rd time drivng it down here. just been sitting for 6 months due to the problem it had. hopefully it will last awhile my next thing would be the transmission but that was also replaced before i bought suppose it has less then 100k but u never know when u buy the car used . i cant really complain truck lasted be for almost a yr driving it like that i was making 2hr trips too driving it like that. well anyways thanks for checking out my post
Old Apr 30, 2009 | 09:55 PM
aquanaut20's Avatar
aquanaut20
You asked and these good fellows answered, why did you just ignore them?
Old Apr 30, 2009 | 09:58 PM
AC94EXPLORER
i didnt ignore them. i thought they were good answer i didnt say they were wrong good to know what they told me and i appreciate them. and thanks for all who replied and i am sorry if i sounded ignored to any of you.
Old Apr 30, 2009 | 10:06 PM
aquanaut20's Avatar
aquanaut20
What was the final diagnosis and what did your mechanic do to fix it??
Old Apr 30, 2009 | 10:08 PM
edgewound's Avatar
edgewound
If the CEL was showing codes P0171,174 that could mean bad upper intake manifold gaskets....they're more like rubber o-rings....causes a vacuum leak and lean condition from the computer.
Injectors might just be jacking up your bill.
Old Apr 30, 2009 | 10:11 PM
AC94EXPLORER
well what happened is that the fuel injectors he replaced cause he said that was the problem to burn one of the rings out in the cylenders. it did have that sweet smell to so it did have a blown head gasket cause i did see the dryed white water marks on the block. the heads tested out fine no cracks which i was suprised cause its a commen issue. i just love the beast its taken me anywhere i wanted to go when it was unning like this for almost a yr and i decided to park it till i can afford to fix it. i dont care what people say about my explorer. thanks
Old Apr 30, 2009 | 10:14 PM
AC94EXPLORER
you know suprising the way it ran my cel light never came on. the only time it came on is when i ran out of gas one time and thats because it was bearly running. but that aint good thats probably why my injectors took a crap. i dont have a working gas gauge so im keeping an eye when i reset the mileage. thanks
AC94EXPLORER
May 9, 2010 10:46 PM
Fords&Farmalls
Aug 3, 2007 12:10 PM
ebexp94
Mar 10, 2007 11:33 AM
robertbourque
Jan 12, 2007 05:18 PM
