Dies in drive
Old Apr 29, 2009 | 06:57 PM
jamesmcowan's Avatar
jamesmcowan
Dies in drive
Friend of mine son has a 95 250 7.3 which has just started to die when you put it in drive. Does not die if in reverse or if shifted into lower gears. Not sure if it will go after starting out and shifting manually. Does this sound like the tc. What to check?
Old Apr 29, 2009 | 09:21 PM
c00nhunterjoe's Avatar
c00nhunterjoe
kind of sounds like a converter clutch locking. have you checked line pressure?
Old Apr 29, 2009 | 09:36 PM
JethroF250's Avatar
JethroF250
x2 with Joe. also does it act like a 5 speed tryin to take off in high gear before it stalls? i know when i lock my tc up the whole truck jumps and stalls out like a 5 speed. but doesnt do it in reverse
Old Apr 29, 2009 | 09:48 PM
c00nhunterjoe
doesnt do it in reverse because of the way the fluid is run and pressures commanded for reverse. madvan and mark can explain it much easier then i can
