Engine Oil recommendations
Old Apr 29, 2009 | 02:05 PM
wreckinball's Avatar
wreckinball
I am changing the grime out of my truck fellas and for those that dont know it, its a 7.3/6.9 diesel. I put both because aside from the bolts having seperate washers that is really the only proof of it being a 6.9. Whish by the way i do trust, just i am always surprised by this beast!
Either way, i was hunting some recommendations on oil. Also does anyone use additives like Lucas Oil products? With the morning smoke i was wondering if i threw in some additive if it would help with this. Thoughts???
Josh
Old Apr 29, 2009 | 02:41 PM
Lazy K's Avatar
Lazy K
One thing I like is to throw in about a qt. of ATF and run the engine up to temperature for about half hour before drainning the old oil.
I use Mobil Delvac 15W40 in my 6.9 with no additive.
However I do use Lucas stabilizer in some machinery engines and really like it.
Old Apr 29, 2009 | 02:57 PM
deano-was-his-name-o's Avatar
What does the ATF do?
Old Apr 29, 2009 | 03:09 PM
wreckinball
ATF for cleaning or what?
Old Apr 29, 2009 | 03:23 PM
dyoung14's Avatar
dyoung14
yea pretty much
Old Apr 29, 2009 | 03:30 PM
wreckinball
call me crazy but safe or no? I am not second guessing you but those are two different liquids on one hand and then ATF has a lot of different chemicals in it. I have heard that you can use ATF in a diesel engine to clean and lube the system but i just dont trust that aspect.
Old Apr 29, 2009 | 04:11 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
ATF as a cleaner, been done for many years.
-Enjoy
fh : )_~
Old Apr 29, 2009 | 04:37 PM
wreckinball
haha just making sure, wondering as usual!
Old Apr 29, 2009 | 04:51 PM
Festus Hagen
Methanoholic
It works pretty good, but people have their different opinions about cleaners....
Some say it just knocks stuff loose, that then gets run through the system.
Others say it
    I've done it for years, I've also drained the oil and replaced it with Diesel and let it run gently for a while and then drained and flushed it all out. But I think I would rethink that in my old age!
    -Enjoy
    fh : )_~
    Old Apr 29, 2009 | 07:48 PM
    Jim Allen's Avatar
    Jim Allen
    Wreckingball, if you use a good detergent motor oil and change it like you should, you don't need any "cleaners." If you want to "clean" the engine up a bit internally, shorten the OCI (oil change interval) for a few changes and good oil will do a pretty good job. You don't want it coming loose all of a sudden. Whatever the oil won't dissolve is better left alone until you tear the engine down and melt off in the hot tank.
    I agree, Festus, about changing your mind about the diesel in the crankcase. Do that too many times and you'll be back riding that old Mule, Ruth.
    Old Apr 29, 2009 | 10:58 PM
    wreckinball
    good points about the OCI, but i just wanted to see about getting a fresher start than i found it! know what i mean? just want to get to a point better than i found it!
    Whit
    Old Apr 29, 2009 | 11:00 PM
    joe f350's Avatar
    joe f350
    be shure to use ur dip stick jimmy
    Old Apr 29, 2009 | 11:04 PM
    wreckinball
    every time i get in the shower, oh wait, you mean on the truck!!! hahahaha
    Old Apr 29, 2009 | 11:10 PM
    joe f350's Avatar
    joe f350
    u dirty boy keel it up wi orbitz gum
    Old Apr 29, 2009 | 11:12 PM
    wreckinball
    lmao!!! will do broski! so with recomendations would it be safe/smart to use lucas to get my engine more sound on the inside?
