I am finally going to replace my orange intake boots with the new ones I got from Clay @ Riffraff.
I was wondering if I am going to need any new gaskets/O-rings?? I am assuming I can just take the babys-butt off to get to the hoses and get them replaced fairly easily? I have searched and cant seem to find any instructions on how to do this-probably so easy anybody can do it right?
I am also going to replace the Intercooler boots and do the CCV Mod and try to get all those oily spots at the boot connections cleaned up.
Costa, leave the babys-butt alone. Take the spider off.
Just take the IC boots at the spider off, then the map sensor hose off at the bottom of the spider, then take the bolt off the front that holds the red and green hoses to the spider. Take the nut off the air heater, be careful of the ceramic spacer. Don't drop it in the valley. Pull the wires off. Loosen the clamps on the orange boots and pull the spider up. Don't forget to take the clamp off the spider to turbo. . You might spray that clamp before you attempt to take it off, could be a little stuck on there.
Thanks Rick thats a great step by step. I thought the spider was the piece that connected the up pipes together.
Since I am going to put all the boots on and the pipes will be out, it might just be the right time for a foil delete and some paint. My weekend is going to be busy.
Sounds like a good plan. Have fun with the foil. lol. Like Glenn said, PICS.
At least get that foil off while the pipes are out. Be prepared for a little bit of a struggle getting the spider back on, those new boots will be much thicker than the stock orange ones. I assume that you got the blue boots from Clay, which I have as well.
OH, and Costa, don't get frustrated when trying to line all the boots and pipes up. . It can get frustrating having to go back and forth with trying to get them back in so all the clamps work. Make darn sure the clamps are on right. I do know what it sounds like when a boot is blown off while WOT. It's louder then you think. I thought I blew the engine.
