Ye Olde Smog Pump
Old Apr 29, 2009 | 07:09 AM
Freaksh0w's Avatar
Freaksh0w
Ye Olde Smog Pump
Ok, I've read a lot of people asking about taking off their smog pump. I will do this TODAY and report back if I can even tell a difference if everyone seems to know this is an ok thing to do. I live in a state that does not check emissions.
I haven't looked in that area of my truck for awhile, but I think I can just take the belt off the pump and all will be well. Is there anything that can happen to my truck from doing this?
Old Apr 29, 2009 | 01:31 PM
86bigred's Avatar
86bigred
i've never noticed any thing.all it does is pump air into the exhaust the reduce emissions.
Old Apr 29, 2009 | 02:19 PM
Freaksh0w's Avatar
Freaksh0w
Well, I just took the belt off and went around driving. I don't really know if I can tell much difference from just normal driving, but I swear... This thing is burning out much easier from a very low roll in 2nd gear (NP435). Before it'd usually just go, or maybe barely make a little screech and then go, but this time, it would just start to light them (or it) up. It has never done this, and this is the exact same spot I always do this.
I am the last person who wants to think I gained performance if I really didn't, and like I said, I don't know if it has done anything while driving normally. If it did do something, it was just enough to help the tire get moving that little bit quicker to let it start burning out from a low speed punch. Every little thing helps the 302 in the 1200RPM area, lol.
I will say, it definitely feels like it's just easier to get the tires spinning.
All I did was take the belt off. The main thing I would like to know is if there are any side effects that can happen to my truck from this?
Old Apr 29, 2009 | 02:28 PM
lew52's Avatar
lew52
I dont know if you get any more performance with out it or not . I dont have one .You dont need it..I would just take the pump off . Looks better saves weight .. Lew
Old Apr 29, 2009 | 04:14 PM
Redneck1465's Avatar
Redneck1465
Its not gonna hurt your truck at all. The only thing that taking if off is going to do to your truck is give it one less pulley for your motor to spin.
Old Apr 29, 2009 | 04:38 PM
Greyf100's Avatar
Greyf100
one less belt pulling on your alternator pulley..
if it was like my truck...14 less vacuum lines to leak, 4 check valves, 38 vacuum connector problems, etc...
hey is there a way to remove the egr spacer and put a normal carb spacer in? waht vehicles did the normal spacer some in? or do you need a pre smog intake?
Old Apr 29, 2009 | 04:45 PM
Redneck1465
I have been told that they only way to completely get rid of the emissions stuff is to go presmog. I plan on getting an new intake that has no smog or egr stuff on it at all.
Old Apr 29, 2009 | 04:47 PM
Greyf100's Avatar
Greyf100
i made an EGR block off plate, and capped the other port (couldnt get the thing out of the spacer to plug it), i dont have any o2 sensors, so the only thing left is the cat and the egr tube from the exhaust manifold to the egr spacer.
Old Apr 29, 2009 | 07:00 PM
Redneck1465
There are no o2's on any carb system...
Old Apr 29, 2009 | 08:07 PM
tcbofade's Avatar
tcbofade
There's one on mine...
Old Apr 29, 2009 | 08:47 PM
Redneck1465
On a carburated system?? What kind of truck do you have???
Old Apr 29, 2009 | 09:29 PM
mybrownie's Avatar
mybrownie
I found that my air pump wasn't connected to anthing and next week I am going to take it off. In the mean time I have been trying to tid y up all those stinkin hoses.
I think in the attached picture you can see my carb spacer...let me know if you find a way to reduce the number of hoses.
Old Apr 29, 2009 | 09:41 PM
86bigred's Avatar
86bigred
feed back carb equipped trucks have o2 sensors.
Old Apr 29, 2009 | 10:52 PM
Franklin2's Avatar
Franklin2
On a EFI truck, taking the smog pump off will cause error codes. Nothing catastrophic, but be warned they will be there.
Taking the EGR off on a EFI truck will also cause error codes, and it may or may not start pinging.
Taking the EGR off on a carbed engine will almost always cause the engine to ping.
Old Apr 30, 2009 | 02:18 AM
Sycostang67's Avatar
Sycostang67
I took the belt off my smog pumps(yes pumps, my truck has 2 of them) 4 years ago and haven't had a problem. My new motor wont have any though. I will save all the crap just in case they do require smogging someday.
