1963 re-wiring EZ-wiring Kit.
I'M starting on a project truck.Its a 63 ford F-100 with a 351 v-8. Now i think i bit off more than i can chew with the re-wiring.I bought a E-Z wiring 21 circuit kit and rats have destroyed the old wires so i have nothing to go by. Has anyone used this and can HELP ME!!!
All the wires in the EZ are labeled every six inches as to function.
You will need to purchase an aftermarket headlight switch as the 63 switch and fuse block wont cut it.
Do you have a 61 shop manual or the 62 63 supplement? These have the stock wiring schematic.
I have a EZ 21 for my 63 and will be using the stock ignition switch, a 78 converted wiper delay and custom AC/Heat panel.
Basically with the kit you use very little of the stock wiring.
Garbz
Garbz
If you run short of wiring in your kit, you can always use regular wire from your local parts house to finish the project.
If you are changing wiring under the hood, you will need to make sure to run a ballast resistor or resistive wire if you plan to run points on your engine as they don't last very long on 12 volts.
The factory gauges run off of a 5 volt regulator which is supplied by 12 volts.
Other wise I think off the top of my head most of the wiring is pretty straight forward.
Jeff
Jeff
Suggest purchasing the 63 Ford Wiring Manual, majority of the Ford parts suppliers carry them but likely find it cheaper purchasing directly from publisher: $7. Strongly suggest not wasting money on the laminated color chart type, speaking from experience, found it to be useless. Anyhow, with any luck the ez kit will have the same wire color codes. Lay out original harness, or what remains of them, as templets, then using the new EZ kit make up new harnesses. Seem to recall there's an article in Classic Truck Magazine on rewiring truck using aftermarket kits, think it was a chevy truck but principle would be same. If interested, go to their website under tech articles and either browse or run a search.
Product List
Product List
ride31486
I know your truck is a 1963 , but this Link may Help some ,this is for a 1964 !
1964 F100 - F750 Wiring Diagrams - The Old Car Manual Project
Wally
Wally
If i have a 73'351 motor. what kind of 12 volt coil do u recommend? and what else would i need to buy? Sorry if i sound like an idiot. But this is all new to me.Im a diesel/heavy equipment mechanic.lol
Ok. but when u said ditch the old points stuff.does that mean i have to change distributer?
Yeah thats what i want to do but when i went to the site. i had no clue which one i needed. Its a 73 351 cleveland. I didnt find anything for that
tractormanbill
04-29-2014 05:40 PM
jagergirll
21
02-04-2012 02:45 AM
cbfomoco
07-23-2008 08:07 PM
joe hoffman
01-24-2006 07:59 PM
