Guys, I know there are many thoughts on this subject however, in looking at new tires (285/70/17) for the 250 PSD, I see that the weight rating on certain (d) tires are the same as (e).
Can a person (or should a person) run these (D) rated tires on this truck?
I don't tow but do often haul full loads of firewood, lumber and gravel.
I have run "D" range tires for several years without a problem towing 4000k trailer,firewood,quads etc...
The "E" range has a stiffer sidewall,you will be ok with the D's if that is the route you choose to go.This subject has been debated on here extensively.
Check the specific ratings of the D you are going to go with. they differ. A high rated one will be fine, I also haul big rather than tow and am going to change to D rated KM2s from my current E rated Good Year Wrangler
Any thoughts ? Comments?
If you aren't towing heavy, I don't really think it matters. The tires you are talking about in a D rating are probably rated at about 3,200 lbs times 4 equals 12,800 lbs. Your truck weighs about 7,800 lbs. That gives you a 5,000 lb margin. On the other hand, the D rated tires may sag more and ride softer than the E's.
Of course, a lot of people on here will say E only. When I bought my truck it had C rated tires on it, I quickly changed that situation.
I'm running D's on the Excursion currently, because they only came in a D rating in the size I wanted. Shouldn't be a problem with the higher load rating on them, just a little softer side wall, and you can't run the psi as high. I run mine at 60 psi on a max 65 psi tire with no problems.
the letter is not so much a rating of how much weight you can carry as a descriptive of how stiff the sidewall is(how well it resists sway). with my 03 camper special a full load of topsoil on d tires swayed like trying to stand up in a canoe, no more D's for me
