Sponsored by: Auxito
clutch packs
Old Apr 28, 2009 | 08:48 PM
tktolen's Avatar
tktolen
clutch packs
can anyone tell me ho to replace my clutch packs on my F150? it has a 9.75 ring gear with 3.55 ratio.
Old Apr 29, 2009 | 09:15 AM
KingRanchMan02's Avatar
KingRanchMan02
This is not a task for someone that is not set up for rear differential service.
Old Apr 29, 2009 | 10:34 AM
tktolen's Avatar
tktolen
i have had expierence with differentials just not with the limited slip. just wonderin if someone could give me some advice that would help!
Old Apr 29, 2009 | 11:05 AM
Sako 75's Avatar
Sako 75
Lots of brass: wedges, blocks, pins, square stock, etc.. Oh yeah, and lots of patience.
Old Apr 30, 2009 | 06:26 PM
Bobby82490's Avatar
Bobby82490
To change the clutch packs in a 9.75 you must either have the ford tool or make one your self. Basically what you need to do is make a tool to push the side spider gears apart, you can use your axle in a vise to keep the spiders from turning. Then you can rotate the housing while you keep the side spider gears from turning, which once you turn it enough you can release the tension on the spider gears and remove them.
I hope that sort of made sense.
Pablo-UA
Apr 8, 2013 05:09 PM
5. Slow
Jan 23, 2011 03:13 PM
tennredneck
Dec 30, 2007 07:37 PM
audimaster
Jun 18, 2007 03:14 AM
bigdmizer
Sep 3, 2006 08:41 PM
