wandering--a summary
Old Apr 28, 2009 | 05:29 PM
flatlander84's Avatar
flatlander84
I think I've read just about everything that is suspension related and I want to make sure I have it.
Other than the things which pertain to every tow vehicle there is including: WD hitch setup, load distribution, tire psi, front end alignment and inspection. . .
These are the things which are excursion exclusive:
1. add rear sway bar
2. adjust steering box
3. Decide whether to leave stock springs or. . .
4. Switch springs to V and B code
Now if I choose to leave the stock springs I should
1. Install RAS, or
2. Install radius rods
If I choose to switch springs I should
1. Put longer shocks in the front.
2. Install 3.5" tapered blocks in the rear.
Does that sum it up?
Old Apr 28, 2009 | 06:00 PM
excursion-a-tor's Avatar
excursion-a-tor
Thumbs up Ex exclusive...
I'm still reading up on it... but I am gonna install my RAS this weekend and then get the steering box. I will then play with my tire pressure and if need be replace my shocks. Springs... I will leave that to the end.
Old Apr 28, 2009 | 06:56 PM
rb8484's Avatar
rb8484
OK dumb question here.....what is RAS??
Old Apr 28, 2009 | 07:25 PM
cbradford's Avatar
cbradford
Roadmaster Active Suspension
Old Apr 28, 2009 | 07:28 PM
cbradford's Avatar
cbradford
Old Apr 28, 2009 | 07:42 PM
Stewart_H's Avatar
Stewart_H
It does indeed, like a mathematician finishing his tax returns!
Stewart
Old Apr 28, 2009 | 09:07 PM
flatlander84
Stewart
Thank you very much
Old May 3, 2009 | 09:02 PM
EXv10's Avatar
EXv10
Hate to be negative but I read the whole speil on the RAS and it looks like just another hyped up gimmick by someone to make some money. I doubt if you would notice any difference with it other than your wallet will be thinner.
Old May 3, 2009 | 09:26 PM
Stewart_H's Avatar
Stewart_H
Spiel from the manufacturers website, or from the many threads and posts here at FTE?
Check out this thread I created. It's a compilation of links regarding the Excursion 4x4 steering wander problem: https://www.ford-trucks.com/forums/789595-attn-dup-steering-wander-search-results-for-you.html
As you check out the different threads, pay attention to posts by Joe (Ex_Hemi_Guy) because he posts a ton of info on the RAS.
Stewart
Old May 3, 2009 | 09:41 PM
EXv10's Avatar
EXv10
Mine doesn't wander. It has no play in the wheel and tracks perfectly and I've owned about 40 cars. It did wander when it needed front end parts. I think the ones that wander need parts. Stock parts.
Old May 3, 2009 | 09:49 PM
Stewart_H's Avatar
Stewart_H
You're a lucky man.
The Excursion is built on the same platform as the F250/350, but Ford decided to put different leaf springs on the Ex. Upgrading to the F250 springs (referred to as the V code, B code mod) is a common modification Excursion owners do to fix the inherent wander problem that plagues most Excursions.
Stewart
Old May 3, 2009 | 10:13 PM
EXv10's Avatar
EXv10
Thanks. I know. It just don't understand why they did it unless they figured a SUV should ride better than a pick up or maybe because they had to get the height down in the ex ?
Old May 3, 2009 | 10:15 PM
aortizexcursion's Avatar
aortizexcursion
I'm sure Joe and every other user of the RAS on here begs to differ.
Old May 3, 2009 | 10:20 PM
aortizexcursion
Yup, they wanted it to ride smoother than the Super Duty.
Old May 3, 2009 | 10:21 PM
EXv10's Avatar
EXv10
Maybe they work. Not sure. Just guessing from experience.
