e4od line pressure
Old Oct 15, 2002 | 01:08 PM
waz's Avatar
waz
e4od line pressure
i currently swaped the rear axle out of an 85 f-150 into a 94 f-150, little did i know that the 94 contained a prox sensor for the psom. (speedometer) without this sensor i have no speedo and the line pressure is outrageos! i instaled a factory vss into the tranny and run the output to pin 4 of the computer, this fixed the line pressure problem for a short time and began to work on the speedo problem. i am not too concerned about the speedo as much as the high line pressure which returned as the tranny is costly to repair, there has got to be a way to lower the pressure electricaly from the output of the eec-iv or the pcm the ipec solenoid i think is wired to the pcm but i am unsure where to find the technical info to locate all i need to make any adjsutment, ford tech needs passwords (dealers only) nobody seems to want to get close to electric trannys for some reason.
can anyone help!!
ps. reinstalling the original axle/housing is not one of my options!:-)
Old Oct 16, 2002 | 06:05 AM
rabidranger's Avatar
rabidranger
e4od line pressure
I don't think you want to set the line pressure constant, it varies with each shift. Check out ebay and others for cd-rom shop manuals, it may have all you are looking for. Good luck.
Old Oct 16, 2002 | 06:43 AM
bartfc's Avatar
bartfc
e4od line pressure
Zack Field
Jul 26, 2019 09:14 AM
RandyFtMohave
Mar 29, 2017 12:40 AM
idahoFORD350
16
Jul 24, 2016 10:04 AM
bpimm
Dec 22, 2015 05:45 PM
ant d
May 11, 2010 01:41 PM
