5spd
Old Apr 28, 2009 | 10:41 AM
Redneck1465's Avatar
Redneck1465
5spd
I found a 5spd out of a 89 F150. I realize that this isnt going to be as strong as the ZF but its only 100 bucks for the trans and transfer case. Can this trans be converted to work with a 351W two wheen drive truck? Would I have to change the tailshaft on it?
Old Apr 28, 2009 | 11:12 AM
Franklin2's Avatar
Franklin2
Let it go. You have to change the output shaft as well as the tailshaft housing. 2wd version should be easy to find.
Old Apr 28, 2009 | 11:23 AM
Redneck1465
Ok thanks Franklin.
Old Apr 28, 2009 | 12:52 PM
Sycostang67's Avatar
Sycostang67
Unless you dont mind having a pointless t-case hanging under your truck. I saw a truck on CL like that. 1995 2wd Diesel dually with a transfercase.
Old Apr 28, 2009 | 02:07 PM
Redneck1465
Wouldnt that have a chance of damaging the T case and then in turn damaging the trans though??
Old Apr 28, 2009 | 06:50 PM
Sycostang67
I dont see how. I've run trucks with no front driveshaft before. As long as the front DS output has a fixed yoke so the fluid doesn't leak out. All it will do is add extra weight to the truck. It's something you could do until you found a 2wd tranny, the only thing is that you would have to have your driveshaft shortened and then lengthened. Heck, $100 is a good deal, grab it and sell it for more to help buy the tranny you need.
Old Apr 28, 2009 | 07:57 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
On that dually, it may have been done for the low range.
We used 4WD's on the ranch for the sole purpose of the low range, didn't really need the 4x4.
-Enjoy
fh : )_~
Yeehaw1
Oct 2, 2012 06:12 AM
Beatertruck
Oct 28, 2011 06:59 PM
fyerser
Apr 28, 2011 04:57 AM
73cntry
Jul 11, 2008 11:22 PM
Redneck1465
20
Feb 10, 2008 10:16 PM
