transfer shift linkage removal
Old Apr 27, 2009 | 01:02 PM
heathrunkles's Avatar
heathrunkles
I am dropping the transfer case. How do you remove the shift linkage? Does it come off the t-case or is it just the 3 19mm w torx holding to the tranny. does the arm from the tranny to tcase just pop off?
Thanks
Old Apr 27, 2009 | 02:34 PM
Neal 97 250's Avatar
Neal 97 250
I never dropped just the t-case. I dropped the tranny and t-case together. To the best of my knowledge here at the desk... I believe it is the bolts on the tranny. Once that is loose you should be able to disconnect it from the t-case or I would just pull it out with the t-case.
Old Apr 28, 2009 | 07:37 AM
helifixer's Avatar
helifixer
you can either remove the bolts, of use a small pry bar and pop either end of the linkage off.
