leaking carb?
Old Apr 27, 2009 | 09:49 AM
kadrocker's Avatar
kadrocker
leaking carb?
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
I noticed there is a small amount of gas sitting on top of my manifold....should I assume my carb needs a new gasket?
Carb probably needs rebuilt- it never has been.
<!-- / message -->
<!-- controls -->
Old Apr 27, 2009 | 10:15 AM
boxer.fan's Avatar
boxer.fan
Yes very good indication of bad gaskets. You dont want any of those gas puddles sitting on a hot manifold as this can cause fire! Head down to your local auto parts shop and get a rebuild kit, a manual and something to drink and go at it.
Old Apr 27, 2009 | 10:20 AM
kadrocker's Avatar
kadrocker
Napa has a rebuild kit in stock for $62...thought it'd be worse than that.
Good thing I set some sun tea out this morning on the back porch!
Old Apr 27, 2009 | 10:50 AM
fmc400's Avatar
fmc400
MSEE
It takes more than a rebuild kit - you need heavy chemicals. You need the gallon can of Chem Dip and a couple cans of spray. Be careful with that stuff. Depending on what came in the rebuild kit, you might need a new base gasket, spacer-to-manifold gasket, and as always a fuel filter. $60 is actually really high for a rebuild kit, but that's around what my last kit from Napa cost. A couple years ago they only cost half that.
Old Apr 27, 2009 | 10:56 AM
kadrocker's Avatar
kadrocker
half?! sheesh!
I'll check out the Chem Dip stuff, thanks for the heads up.
Old Apr 27, 2009 | 01:43 PM
Jermafenser's Avatar
Jermafenser
$60? Must be some kinda exotic carb!
My rebuild kit cost $30 from NAPA, and I bought it last month.
What kind of carb? Is the tag still there?
Old Apr 27, 2009 | 02:41 PM
kadrocker's Avatar
kadrocker
tag reads: D5TE-EA (top line) 6A5 (second line)
$30 you say, huh? Hmm....lemme check this out some more before I buy...
edit- it's the factory 4 barrell Holley
edit#2- i just realized I had that info in my sig, haha.
Old Apr 27, 2009 | 02:56 PM
garlindethfury's Avatar
garlindethfury
The reason your rebuild kit is so expensive is the fact that your carb is a holly... as soon as you see that name just plan on spending twice as much... I had a simmilar problem with the holly on my truck and after talking with a lot of old timers I just decided to for go the holly and installed a edelbrock, and never looked back... the only down side i have with the edelbrock is when I am off roading and i hit a hill some times the truck floods out...
also the rebuild kits for edelbrock carbs are about $25...
Old Apr 27, 2009 | 02:59 PM
kadrocker's Avatar
kadrocker
You're probably right garlindethfury.
I thought all the factory carbs back then were Holley's.
My dad got this truck new, and he gave it to me a few weeks ago- I wanna keep it original and stock as possible. I don't have the heart to swap carbs out! plus I don't have the cash...I'm a cheap *******! haha
Old Apr 27, 2009 | 03:05 PM
garlindethfury
yeah I am cheap as well... but when it comes to my truck or eating... my truck always wins... I have had it drilled into my skull since it was a kid... treat your truck nice and it will treat you nice... so i treat my truck as nice as possible...
Old Apr 27, 2009 | 03:41 PM
Jermafenser
I think you've started a thread or two on this carburetor before...
D5TE-EA = 1975/76 F150/F350, 390 V8 4v with automatic transmission, non-Calif emissions. From serial # W00001.
6A5 = assembled January 5, 1976.
The $60 price tag now makes sense.
The choke pulloff usually quit working at this point in its life. I haven't found an original choke pulloff that still holds vacuum. And I've tested over 20 of them!
