A brand new 351 engine from Ford runs about $2500 for long block. 460 engine can't be much more. Ford never really tapped the full potential of these two engines before they went to the modular engines. Had Ford used a Sportsman block and decent aftermarket heads on a 351 they could have gotten much better performance and longevity out of that engine that would have been as good or better than any modular engine in a truck for much less money. It would have been better than anything GM made in a 1/2 ton pickup. The only thing really lacking on the 460 was a good set of cylinder heads. That motor was the best gas engine Ford ever put into a truck. Unfortunately, Ford is still paying for some of the decisions of Jaques Nasser.
I can't imagine the crying some people on here would do if there was a DOHC motor. baaaawwww, there isn't torque at idle, baaawwwwww
true story. that's the biggest problem. a DOHC motor has next to no torque compared to SOHC motors. plus way more things could go wrong. to many moving parts. I wish they'd just go back 100% to pushrod motors.
wow your signature doesn't lie does it? JK lol. but if you hang around long enough you'll end up knowing more than some of your local mechanics. well idk bout that far but you'll know enough to keep your truck running like brand new.
It is not that they have no torque, the powerbands are different. I am glad they dumped the SBFs in favor of the modular motors.
true bout the powerbands. DOHC motors have a higher rpm power band before you start hitting the hp. if you want a racing truck go buy a DOHC crate motor and drop it in. but for an everyday driver sohc is the way to go.
but why would you rather modular motor over pushrod motors? the pushrods are much much easier to work on. parts are SOOOO much cheaper.
I think that if Ford used the same engine management strategy on a push rod motor that's used on the current modular engines, it would do just as well down low if not better. In my truck, I want all of the power to be in the lower rpm ranges. I'm not going to want to push it much past 3500 rpm working it hard. If I get good torque and power numbers at the lower rpm range, I'll also get better fuel efficiency. Don't forget, the power band wasn't all that great on the earlier mod motored trucks. And the push rod engines will take up less space under the hood and be much easier to repair and service, thus making ownership a little less expensive.
the GT500 motor is a $15,000 option. The Cobra 4v is a $12,000 option
you can buy a brand new 5.4 for about $5,000...there is alot of money involved in a 4v motor. Especially when you start bumping the displacement.
money is what makes the world go round. A 4v 5.4 would sell in the F-150, but not enough to recoup the R&D and other supply factors.
everything boils down to a #'s game, and Ford has done the figures.
this is true, but with a new supercharger the gt500 makes some where in the 700hp mark, supercharge our engines and you get 450 on a good day. With the power numbers and production numbers the pricing isn't a good comparison, it is like comparing a house cat and a cougar, they are related but different lol. I don't think DOHC should be the every day motor but for something like the L (when they made it), the new raptor, or the harley it would be great in them.
but how much more r&d would be needed, a new electronic system and a upgraded trans? what else? I would think it would be cost effective but maybe not.
The SBF was 40 years old when they canned it. You can only milk a design for so long before it is time to get rid of them. They used EEC V on the 302 in the Explorers and they weren't as wonderful as you claim they would be.
The modular engines are designed to turn higher RPMs. Why don't you want to use a motor in its powerband? The pushrod motors may take up less space under the hood, but what is going to make the cost of ownership less? They are not hard to work on as is.
They used EEC-V on the 97-03 F series also and they weren't very good either. They weren't as fuel efficient as the trucks they replaced or the trucks that replaced them and had no low end torque. The Navigator made it's torque way past 3500 RPM. Put the strategies that are used in the 04 and newer mod motor trucks with a push rod engine and it'll do fine for less money. With a more rigid block and good cylinder heads and the right hydraulic roller cam that old 351 had a lot left in it in terms of performance and longevity. And it would be cheaper to build for Ford and cheaper to own for us, the consumers. And it'll do anything that a mod motor will.
Toyota did OK with its OHC engines. I think OHC is definately an improvement over pushrods. It all depends on how the engine is made.
How much more money should they throw at an aged platform? A more rigid block and different heads is going to increase the price of the motor and you are still sitting on a design that is 40 years old. Not to mention the not so stellar fuel economy...
