dana 24 t case???
Old Apr 26, 2009 | 11:06 AM
hotroddually's Avatar
hotroddually
dana 24 t case???
i asked in the 4x4 forum,but no replies. i have 2 t cases,both divorced. they are made by dana,and are model 24. i was told they are from an early bronco(66-77) but i researched ,and found that all early broncos are fitted from the factory with dana 20 t cases. i want to find out what the dana 24 is out of. i was curious on how reliable and tough this t case is.
Old Apr 26, 2009 | 01:36 PM
Ford_Six's Avatar
Ford_Six
It was interchangeable and pretty much as stout as the NP205. It was used in the F250s, and in some aftermarket conversions.
Old Apr 26, 2009 | 04:39 PM
4x4lugnut's Avatar
4x4lugnut
24's came in F100's and F250's. I still have a 62 and a 65 that both have a 24. Yes, they are very reliable. I never had any problem with them and these trucks were used and abused. I would be interested in knowing how the 24 and the 205 gear ratios compare, if anyone happens to know.
Old Apr 27, 2009 | 02:42 PM
75F350's Avatar
75F350
This was my reply in the off road forum, and it addresses the ratio issue. The NP has a slight advantage, with a 1.98:1
suprised nobody has jumped on this.
Here you go.
Dana 24:
'Divorced' part-time 2-speed (hi-lo), used on '59-'72 F250-F350s 4x4s and were also pretty common in the '59-'66 F100s. They were also used in 6-cylinder '73-'75 F100/F150 trucks. Cast iron, gear drive, 1.86:1 low ratio. It's a tough case but lacks a low range, and parts are getting hard to find for this.
NP205 is a better candidate, but the Dana is pretty tough.
Old Apr 27, 2009 | 06:17 PM
hotroddually
thanks guys, i have never seen one of these in a truck before. im building a trail buggy from an old bronco frame.3/4 ton axles dana 44 front dana 60 rear 4.88 gears both will be spooled. trans will be a np 435, engine a mild 302. tires are 36 inch. truck will weigh around 3500-4000 lbs. im hoping this t case will hold up to some mild trail use.
