which 8 Lug wheels
Old Apr 25, 2009 | 11:52 PM
dhigh45's Avatar
dhigh45
which 8 Lug wheels
Which 8 lug wheels will fit 77 F250 3/4 ton? the truck i just bought has OE split rims (WOW) Are one ton van wheels same pattern? what years are the same? This is my first 8 lug so all info will be fully digested thank you. I would like to reuse original hub caps
Old Apr 25, 2009 | 11:57 PM
77f2504by4's Avatar
77f2504by4
basically any ford 96 or older will fit. most dodge rims aswell, last i checked and this was 2-3 years ago the new dodge rims fit aswell, as a general rule chevy rims dont fit, some do but others dont, they have a smaller center hole. and yes van rims will fit provided they are 8-lug and 1996 or older.
Old Apr 26, 2009 | 01:46 AM
Sycostang67's Avatar
Sycostang67
Any aftermarket 8 lug wheels should fit as long as they weren't meant for the 99 and newer fords with the metric lug pattern. The problem with using some OEM chevy wheels is occasionally the center hole is too small to fit the ford axle.
Old Apr 26, 2009 | 03:27 AM
Jermafenser's Avatar
Jermafenser
Ford vans still use the old lug pattern...don't know if the '08 redesign still retain it.
TexanAmmo
Dec 3, 2016 01:47 PM
bignewf
Apr 21, 2016 05:24 PM
bignewf
Apr 21, 2016 12:31 PM
pineconeford
Apr 20, 2014 09:05 PM
1970moose
Dec 5, 2002 12:37 AM
