aftermarket posi
Old Oct 27, 2002 | 09:20 PM
4rdgasm's Avatar
4rdgasm
Post aftermarket posi
I am looking at getting an Auburn posi center section, or the Detroit locker. I have heard good things about both, but wanted to know what your guy's experiences have been. Or is there a better one, more economical??
Tx.
Old Oct 28, 2002 | 11:49 PM
sand man's Avatar
sand man
aftermarket posi
if you have an 8.8 or 9 inch definately go with the auburn "pro" not the high performance. the auburn pro is a much stronger differential and is a limmited slip which will lock both wheels when you are applying torque "accelerating" and will release when you go around a turn for a much quieter and comfortable ride than the detroit locker and is also much more affordable at $370 on www.moserengineering.com if you are not running alot of horsepower and want to save the $60 you can go with the auburn high performance buy i would strongly suggest going with the pro its only another 60 and you wont have to worry about blowing it. i called and asked about the torque it would hold and they said as long as you are not running faster than an 11 sec quarter mile you dont have to worry about the pro letting go. Good Luck let me know if you find something better or cheaper or both
Old Oct 29, 2002 | 06:57 PM
wildjon300ci's Avatar
wildjon300ci
aftermarket posi
Old Oct 29, 2002 | 10:33 PM
4rdgasm's Avatar
4rdgasm
aftermarket posi
Kool!! thanks for all the info. I'm just going to check out that website, see if I can get more info. tx again.
lasitter
Jun 13, 2014 12:32 PM
cmullins
Apr 6, 2012 02:43 PM
89ford73
13
Oct 20, 2008 07:39 PM
ford_racing_4_life
1983 - 2012 Ranger & B-Series
Feb 2, 2007 07:11 AM
Dusty McGuire
Aug 5, 1999 07:52 PM
