97 E-150 Conversion Keyless Entry Fix
Old Sep 28, 2019 | 01:22 AM
turbogus's Avatar
turbogus
Hey Smashed Pumpkins, where did you get your new RKE ?
Old Sep 28, 2019 | 09:07 AM
dcgayhart's Avatar
dcgayhart
I had to send unit I bought back, it worked worse than mine. I'm back to square one. If anyone find a good replacement let me know.
Old Nov 20, 2019 | 03:36 AM
turbogus's Avatar
turbogus
I FOUND THE FIX !!!
...at least on mine. I did a front brake job recently and the dome lights stayed on draining the battery. After charging the RKE started working. I intentionally made mine fail today and, while at work I disconnected the battery. Upon reconnecting the RKE started working again. So, in conclusion as no RKE modules seem to be available I'm going to rig a switch to cut power to my RKE module to force a reset
Old Nov 21, 2019 | 06:00 AM
dcgayhart's Avatar
dcgayhart
Originally Posted by turbogus
I FOUND THE FIX !!!
I'm glad that worked for you.
Old May 16, 2020 | 09:07 AM
Mach5's Avatar
Mach5
I have similar issues with the RKE in my 99 van. But I don't see any bad solder joints and the connector itself seems tight to the PCB. The entire PCB and all components appear to have been dipped in some type of sealant, making any repair difficult because you have to get the sealant off to do any solder/desoldering. The OP's photos aren't showing anymore, so I wanted to ask if they could be reposted (yes I know this thread is ancient in internet forum terms). Still, I remain hopeful. :-)
Old May 17, 2020 | 05:18 AM
JWA's Avatar
JWA
The opening post is 11 years old so its not unusual the photos are no longer visible. The OP hasn't been active here since 2012.
As suggested in another reply on this same topic find a reputable RKE repair outfit to see what they might do to refurbish your existing RKE module. A visual inspection may or may not show what might need attention----sadly such checking doesn't reveal anything so obvious that its an easy DIY repair.
Old Jan 16, 2025 | 03:16 AM
vagabondvivant's Avatar
vagabondvivant
3rd Gear
Just chiming in and resurrecting a 13 year-old thread to say my '96 E-150 has the same issue and I've likewise been trying in vain to find a solution or replacement. I removed the RKE and inspected the circuit board, but everything seems fine and firmly connected. I do know it's a connection issue because pressing and wiggling the wire ribbon will cause the locks to randomly lock and unlock, but I can't for the life of me figure out exactly where the issue is.
Here's hoping this reply revives the thread long enough for someone with an answer to see it.
Old Jan 17, 2025 | 11:02 PM
Turbogus 1's Avatar
Turbogus 1
Spo my 'Strayhound' van '98 E 150 I checked the capacitors on the circuit board and with the help of a capacitor checking device I found two weren't up to spec. I ordered replacements from the web, I forget where but dig this counterfeit merchandise goes right down to components! These worked for a few months then failed. Once I get remotivated I'll get some new capacitors from Digikey or Mouser and give it another shot.
jason867
Apr 1, 2020 07:39 PM
kornfanjoe
Feb 7, 2020 05:42 AM
1985 Bronco
Jul 11, 2017 08:00 PM
jason867
26
May 3, 2017 04:49 PM
tabijan
Apr 10, 2016 03:39 PM
