Bed removal
Old Apr 25, 2009 | 11:53 AM
82-100's Avatar
82-100
Well I live in Kentucky and we get our fair share of rust here and I tell you I commited to this project before I knew what I was getting myself into. It took 2 days a ratchet w/ breaker bar, grinder, mig welder, and a torch. They are a real PITA. You cant just cut them all off with a torch either cause the front 2 bolts on the drivers side is about 2 inches from the tank. When you get ready to loosen them with a ratchet and socket be ready for the bolt to turn(I mig welded them to the bed.) And I'll tell you if you plan on grinding the bolts be ready to sit for a while cause those things are TOUGH.
Old Apr 25, 2009 | 08:23 PM
Redneck1465's Avatar
Redneck1465
I took off two beds while I've been here in Minnesota and they just dump the salt on the roads around here. I went at it with a breaker bar and broke em loose if the impact wouldnt break them loose.
Daves94vert
Jul 28, 2011 10:04 AM
davewave649
23
Jul 17, 2011 09:38 AM
davebar
2004 - 2008 F150
Oct 19, 2008 01:40 PM
dave2
Aug 29, 2006 01:50 PM
wvmudder
May 24, 2005 09:18 PM
