This is a good one!!!
Old Oct 29, 2002 | 07:20 PM
69 F100 4x4's Avatar
69 F100 4x4
The other day i was driving down the road and my rear end felt a little loose, so i stopped and air up my tires. When i got back on the road i got worse now it was rocking the whole truck. I limped it to school and started looking for a broken leaf spring or something.Then i saw that my 9in. axle housing had actually cracke at the welding. I figure the previous owner wrapped a chain around it to pull out another truck. So any way i call up a few places foe a housing, and since i needed bearings, the axles too. The cheapest i could find was $150. So I went and paid for it so they could pull it for me. When i got back to pick it up it wasnt a 9 in. it was a d-44. the guy swore up and down that it was a 9 in. and that my axle must be an old style since the pumpkin came out the front. Its was however a complete axle and i didnt have the time to find another so i grabbed it. It bolted up fine but ofcourse the driveshaft didnt fit so i had to have it shortened.
MY ?: is the D44 rear end any stronger than the 9in.??
thanks alot
Old Oct 29, 2002 | 08:34 PM
mwc4275's Avatar
mwc4275
The 9 inch is probably stronger, and it's easier to work on, and parts are cheaper.
Old Oct 29, 2002 | 09:43 PM
bronco351's Avatar
bronco351
That is a great deal. My axle cost me $800. Though I did get a 1 YR warranty!!
Old Oct 29, 2002 | 09:56 PM
Polkat's Avatar
Polkat
The D44 is no slouch either so don't feel too bad!
Old Oct 30, 2002 | 11:39 PM
69 F100 4x4
Thanks for all the replies. I figure the D44 will do alright till i get around to getting another 9in housing. I did go from 3.50( I think)gears on my 9in to 2.71 on the d44. Ill notice that when i get my driveshaft back. Maybe itll be better i could only get up to about 7 mph in 1st with the 3.50s. well ill let ya know
Old Nov 1, 2002 | 07:10 PM
cbwarrior's Avatar
cbwarrior
Post This is a good one!!!
You say the gear ratios are different from those you had before? Don't put it into 4WD until you make the front and rear ratios match again!!!!!
Old Nov 1, 2002 | 07:24 PM
cbwarrior's Avatar
cbwarrior
hasteranger
May 20, 2012 01:31 PM
keyul
Offroad & 4x4
Dec 20, 2011 03:23 PM
sevensecondsuv
Oct 15, 2011 10:55 PM
BlueOvalBud
35
Apr 1, 2011 10:22 AM
Lee Lichterman
19
Dec 12, 2004 03:10 PM
