bed pics needed
Old Apr 24, 2009 | 03:04 PM
needhelp49's Avatar
needhelp49
bed pics needed
img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=214414&.jpg[/img] anyone have a pic of what this is supposed to look like
Old Apr 24, 2009 | 03:13 PM
mostly52f1's Avatar
mostly52f1
wow, thats almost what my bed looked like lol.
Old Apr 24, 2009 | 04:35 PM
havi's Avatar
havi
I'll have the Roast Duck
looks like mine as well. The second truck didn't even have one. Not what you wanted to see is it, lol.
Old Apr 24, 2009 | 09:51 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Try looking in some of the vendors catalogs for bed pics, and/or individual pieces
https://www.mackhils.com/mack_produc...p?CategoryNo=3
Bobby
Old Apr 24, 2009 | 11:28 PM
KGP50's Avatar
KGP50
[IMG][/IMG]
Needhelp49, here's a similar one I'm assembling - for a '41 (it's a Mack Products bed). It's probably the same bed used for a '49. No instructions supplied with bed and none online that I found --- would be glad to try to answer any questions about my experience with the assembly.
Old Apr 25, 2009 | 02:18 AM
Julies Cool F1's Avatar
Julies Cool F1
I can't see your pic and don't know if you have an Express Bed or Pick-up Bed, but let me download what I have and hope it helps.
Name:  F2 and F3 Express Bed Profile.jpg
Name:  F1 Pick-up Bed Dimensions 1.jpg
Name:  Bed Pick-up and Express.jpg
If you are working on your bed, I recommend you visit the folks at MAR-K at
MAR-K Classic Truck Parts made in Oklahoma City, USA
Shoot, maybe we can even get a few words from "MAR-K Mark."
Old Apr 25, 2009 | 07:44 AM
needhelp49's Avatar
needhelp49
kg if that tail gate was off with no floor it would be perfect. i need to know what the rear cross member looks like.
i was going to buy a new one but with the wife wanting a baby that went out the door.
i even draged the running boards out of the scrap pile and 7 hours later thay look great.
so i thought i can fix the bed to julie those help and it a reg bed
Old Apr 25, 2009 | 03:04 PM
Julies Cool F1
Hi again!
I think despite the raised panels on your bed sides, the rounded stake pockets and the different tailgate (yes the 51 and 52 was slightly different where th etab was located for chain locking)
I have pictures of my bed (51 Pick-up Box) when I primed it. I'll post a couple pics. If you need a specific view, let me know I may have a picture of a close up.
Name:  B2 Bed Floor and Front Panel Removed.jpg
Name:  C Tailgate Inside.jpg
Name:  B11 Rear Channel Patches and Roller Pan Primed.jpg
That back piece is just a rectangular tube it measures 1 3/4" x 3 7/8" x 49 1/2-3/4" outside....
Old Apr 25, 2009 | 03:57 PM
KGP50's Avatar
KGP50
[/IMG]
[/IMG]
Needhelp49 ... Julie's supplied some good stuff there w/ the pics and measurements. My bed is a bit earlier model but if you're rear sill is rounded at the bottom, this may give you some idea. The rear stake pockets and the rear sill fit flush with each other at the rear and must be welded along their seams. It requires that you notch out the side panel where it meets the rear sill and cut off the corresponding length of the flange on the rear stake pocket. Top photo shows where the stake pocket insert connects the rear sill and stake pocket (I plug welded it from the stake pocket and face of rear sill as well as at its top surface). Also, in the rear sill I welded in two short pieces of square tube (each is about one-third of the way in from each side) tying the front side of the sill to the back side) to keep it from bowing in the middle.
Hope this helps.
-Ken
Old Apr 25, 2009 | 08:10 PM
needhelp49's Avatar
needhelp49
those are exactly what i need thanks guys
Old Apr 26, 2009 | 08:41 PM
dickie50's Avatar
dickie50
Smile pickup bed
Thanks for the great pictures - pictures are indeed worth a thousand words. These are just what I need to get me going. I apologize if this posted message doesn't get to the correct area but I'm new to the site & haven't quite figured how to navigate it yet. Thanks again, Dick.
Old Apr 27, 2009 | 08:41 AM
bobbytnm's Avatar
bobbytnm
I built my own rear sill piece on my bed. I went ahead and bought new stake pockets but fabbed my own lower sill. There's pics in this gallery;
https://www.ford-trucks.com/user_gal...&albumid=25204
I used 2x3 rectangular tubing saddled over some 2" round tubing
Bobby
Old Apr 27, 2009 | 10:13 AM
needhelp49's Avatar
needhelp49
bobby your the man im copying your rear instead of buying. So with fixing the running boards and the bed and rear fenders this site has saved me 1000s of dollars
Old Apr 27, 2009 | 10:26 AM
bobbytnm's Avatar
bobbytnm
LOL...
My whole bed is a little unconventional and I'm not using a standard bed floor or sub floor. Keep in mind that the rear sill has the mounting points that attach the bed to the frame. I didn't use these but they wouldn't be hard to fabricate.
I also welded in some 1/4" steel pads inside the stake pocket so that I could drill and tap them for the tailgate hinges instead of having bolts all the way through the stake pockets (a 3/8" thick pad would have been better)
Bobby
Old Apr 27, 2009 | 03:16 PM
dickie50's Avatar
dickie50
Nicely done - I appreciate the pictures. Did you spot weld the rear stake pockets to the bed sides or did you plug weld them? I assume you spot welded them as I think you said you spot welded the front panel to the bed sides. Anyway - you done good. Dick
