2000 PSD starting/running help!
Old Apr 23, 2009 | 10:58 PM
shortys07's Avatar
shortys07
Truck- 2000 PSD 7.3 auto
Story line- Truck started up great and ran like it always has last night.
Go to start it today and i wait for it to prime and wait for the wait to start light etc. But then i notice the dash lights dimmed again. I start the truck and it runs for about 5mins then just stalls out of no were like i turned the ignition off. no sputter, just dead. So i go to start it again and the truck turns right over and idles around 5 to 10min then i go to put it in drive and it stalls again. Now when i turn the key to the on postion i notice the dash lights and cab light keep dimming every 20 seconds or so like theres a short or load present. And now the truck wont start. Ive checked the following-
Oil level
Fuel filter
Fuel pump
No codes
CPS changed 2 years ago(grey)
Batterys both 12.5
glow plugs
gpr
Im stumped on how it just dies out of no where. Any help would be appreciated. thanks
Old Apr 24, 2009 | 01:18 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I am sorry I can't help on this one but here is a bump...
Old Apr 24, 2009 | 01:34 AM
duck fan's Avatar
duck fan
Because racetruck
You say both batteries are 12.5 but how are the connections at the posts as well as your ground? I would start there. My guess is that one of you cables are loose or corroded, either that or you have a bad ground somewhere.
Old Apr 24, 2009 | 03:10 AM
Visseroth's Avatar
Visseroth
I agree w/duck fan.....
PSD are very power hungry beasts as they are computer driven w/high voltage injectors and loose connections will cause resistance, carbon build up and maybe even small electrical spikes.
Be sure to load test each battery and then fire the rig up and make sure your voltage goes above 13v. You should get about 14v or so and that means the alternator is charging the batteries.
Also if you have a chip then make sure it is well seated. I was having some issues with my truck and weird idles because my chip had built up some carbon on it's connections. I pulled the computer out with the chip, cleaned the contacts, put some electronic lube on each individual contact and put it back in w/ a new strap and it seems to have cleared up my issues.
I figured the chip issue out because I had just taken my truck to the shop and the guy there said there were codes in the computer's logs. I thought the chip could have had something to do with it and put my hand on it while it was running and the truck died as if I turned off the key. Now I can wiggle the thing all about and it does nothing to the truck.
There are some ideas, give'm a shot.
Old Apr 24, 2009 | 12:06 PM
shortys07's Avatar
shortys07
I did already load test each battery and they passed. Charged both of them up just for peace of mind when i go to start it this morning. I clean my terminals and the posts with a wire brush and i removed my pos chip from banks(got it with the truck, getting dp soon). and the truck starts right up! idles fine all the way to operating temp and then i decide to drive it and it drives perfect. so hopefully it happens again so i can further diagnose the problem but until then ill be driving the truck. thanks guys really appreciate it.
Old Apr 24, 2009 | 01:09 PM
Visseroth's Avatar
Visseroth
Anytime. Glad a newbie could be of help....
Also, be sure your dp is getting a good contact and that there isn't carbon built up on the contacts. Mine was being weird too and I had to pull the PCM out of the truck, clean the contacts and for peace of mind as you called it, I put some electronic lube on the contacts. I don't remember the name of it but you can get it from the store. I put it on each individual contact instead of spreading it across the board so as to avoid a short between pins but to ensure contact of each contact.
DeBoerJM
Apr 14, 2014 08:06 PM
superhooperduty
Aug 20, 2012 12:27 PM
marcomjl
Jan 24, 2011 08:49 PM
tomanycars
Jul 15, 2010 10:27 PM
Chaos 95
Electrical Systems/Wiring
Oct 19, 2004 04:27 PM
