Dear, torq control
Old Apr 27, 2009 | 10:56 AM
04XLTRUNNER's Avatar
04XLTRUNNER
i didnt have a button on my 05 but when i set my programmer it gave me the option to turn it off. mine was a 4x4 but in 2wd it wouldnt really let me spin the tires until after i turned it off.
Old Apr 27, 2009 | 02:06 PM
05yellowgt's Avatar
05yellowgt
The Ford Drive by Wire is a VERY complex system. It isn't at all like other DBW systems out there that simply work in a "follow" mode and mimic exactly what the gas pedal does. The Ford system uses a VERY complex set of calculations to determine the torque desired and the required throttle postion, fuel, spark, cam angle, and CMCP angle to output that amount of torque.
It isn't very uncommon at all to have the pedal depressed 25% but the ECU decides to open the throttle 80% because you are going up hill. There are also many different torque reductions that take place, between upshifts and downshifts, 4x4 engage and disengage ect to make for a smooth ride and also keep wear and tear down on the drivetrain.
Old Apr 27, 2009 | 03:44 PM
Sethw3's Avatar
Sethw3
So is there any way to bypass Ford's DBW system.... I can control my foot?
Old Apr 27, 2009 | 03:49 PM
05yellowgt's Avatar
05yellowgt
Not that I know of. I am by no means an expert. Just talked to a lot of people and been around the DBW system with my 05 Mustang for a while.
73-302f100
Mar 30, 2014 09:02 PM
snakedoc
Mar 26, 2012 08:18 PM
odiesf350
Mar 4, 2012 06:10 PM
ghunt
General Diesel Discussion
36
Oct 25, 2008 11:57 PM
stover007
May 8, 2002 08:10 PM
