I am putting a C6 in my 1965 F100 and want to know which port on the transmission is the pressure port and which one is the return. I can assume the front one is the pressure but I want to make sure.
yes, the front port is the pressure port and rear is the return.
are you using a cooler and the radiator, or just a cooler.
if your using both, you usually should go the the cooler first
then the radiator, then back to the radiator.
good luck
glen bransfield
houston tx
