turbo problem
Old Apr 23, 2009 | 06:52 PM
toolmann's Avatar
toolmann
Question turbo problem
I have a 2004 F-550 with 128,000 miles. I was running the interstate about 70 mph and started loosing power. I checked the guages and all was ok, no running hot, and plenty of oil. Pulled into the service lane an shut the engine off, it restarted fine but would not rev higher than an idel. Had it towed home and checked it with the diogonostic system and received a code that read " turbo / supercharger boost pressure not detected" also P2262 mechanical. If anyone has had a problem like this please shed some light. And thank you to the veteran forum guys for steering me in the right direction. Ted
Old Apr 23, 2009 | 07:14 PM
bismic's Avatar
bismic
P2262 - possible causes:
MAP hose
MAP sensor
CAC system leaks
Intake leaks
EP sensor
Exhaust restriction
