Another "PLUG" question
As i am aware of the problematic issues with the earlier 5.4L plug removal issues and have heard minimal responses regarding problems with the 05-07 5.4l.
I am getting ready to do mine and wanted to get ideas on dealer prices as i already knew they were pricy so i asked around to the local dealers. out of the 3 dealers i contacted i got the following prices:
Dealer #1 -$425 (3 hrs labor)
Dealer #2 -$334 (didn't specify)
Dealer #3- $506 (3 hrs labor)
Plugs list at dealer at $18.19
Ford parts direct- $7.96
ANYWAY
I plan to do these myself and wanted to get a consensus on how many of you had had breakage or problems removing and access. (05-07 5.4L ONLY)
THANKS
https://www.ford-trucks.com/forums/8...broke-2-a.html
Some trucks are better than others
I used the Champions in my truck, to replace th Motorcrafts. I am not a big fan of Champions, but I have 7,000 on them and have had no problems so far. The Champion design is much better than the Motorcrafts. I also put the high temp Anti seize on also.
http://www.wfservices.biz/TSB%20Ford...%20removal.pdf
