Sponsored by: Real Truck
Another "PLUG" question
Old Apr 23, 2009 | 04:20 PM
DAVE67FD's Avatar
DAVE67FD
I know this has been asked before (probably many) but my search didn't yied effective results based on the 05-07 spark plug replacement.
As i am aware of the problematic issues with the earlier 5.4L plug removal issues and have heard minimal responses regarding problems with the 05-07 5.4l.
I am getting ready to do mine and wanted to get ideas on dealer prices as i already knew they were pricy so i asked around to the local dealers. out of the 3 dealers i contacted i got the following prices:
Dealer #1 -$425 (3 hrs labor)
Dealer #2 -$334 (didn't specify)
Dealer #3- $506 (3 hrs labor)
Plugs list at dealer at $18.19
Ford parts direct- $7.96
ANYWAY
I plan to do these myself and wanted to get a consensus on how many of you had had breakage or problems removing and access. (05-07 5.4L ONLY)
THANKS
Old Apr 23, 2009 | 08:11 PM
Furian's Avatar
Furian
You Keep What You Kill
Subscribed!
Old Apr 23, 2009 | 08:28 PM
FX4 5.4's Avatar
FX4 5.4
it is a 3 day project. start it on a friday and finish it on a sunday. i broke 2. here is a link to the post i did after my removal:
https://www.ford-trucks.com/forums/8...broke-2-a.html
Some trucks are better than others
Old Apr 23, 2009 | 09:36 PM
motown's Avatar
motown
Here's what I did, and every plug came out unbelievably easy. I ran marvel Mystry oil in every tank for a month prior to changing my plugs. All I had to do was break them loose with a ratchet and hand thread them out. The marvel Mystry oil has mint oil, which softens carbon. Someone did the same thing over on the F150 side, and had the same results as I did.
I used the Champions in my truck, to replace th Motorcrafts. I am not a big fan of Champions, but I have 7,000 on them and have had no problems so far. The Champion design is much better than the Motorcrafts. I also put the high temp Anti seize on also.
Old Apr 23, 2009 | 10:27 PM
DAVE67FD's Avatar
DAVE67FD
It seems per the TSB and your trucks years (05) this problem continued thru to 05. Am i to say the 06 and up is exempt or reduced from this problem? my truck was built in april 06.
Old Apr 24, 2009 | 08:18 AM
motown's Avatar
motown
I think the change to the heads was in the fall of 2007, it says on the latest TSB.
http://www.wfservices.biz/TSB%20Ford...%20removal.pdf
