Still need help
Old Apr 23, 2009 | 10:27 AM
ford_man's Avatar
ford_man
Question Still need help
when me and my friend started working on the truck last night, we got it timed and then messed with the carb for a bit, but he wanted me to check my spark plugs so i looked at them, they looked good, but one broke on me when i was taking it off. going to buy new ones today, they were champions going to put motorcraft on them. But it still seems to spudder a bit, was wondering if it could have been a broken spark plug a long time ago. well any feed back would be great. O and again 1979 f150 4x4 with 300 I6 offy intake, 500 CFM eldebrock, and an rv cam.
Thanks
Old Apr 23, 2009 | 11:15 AM
northerndave's Avatar
northerndave
so.... what's your question?
you did replace the plugs and it still misses or???
Old Apr 23, 2009 | 11:38 AM
ford_man's Avatar
ford_man
haven't replaced the plugs yet am going to tonight. I was just wondering if you guys thought it was the plugs or something different. My friend said a burnt valve, but how do you tell if you got one of them
Old Apr 23, 2009 | 11:39 AM
Tees77f150's Avatar
Tees77f150
I think he is wondering if the broken spark plug was causing the sputtering all along.
Old Apr 23, 2009 | 11:45 AM
427 fordman's Avatar
427 fordman
I would say change your plugs tonite and then let us know if it works or still does what it was. Also explain a little better as far as a "sputter" and people will help as much as they can
Old Apr 23, 2009 | 11:46 AM
ford_man's Avatar
ford_man
Ten 4 on that Tees77f150
Old Apr 23, 2009 | 12:13 PM
Jermafenser's Avatar
Jermafenser
Use a vacuum gauge to find out if you have a burnt valve...or two.
Old Apr 23, 2009 | 12:18 PM
northerndave
how's the rest of your ignition system? cap, rotor, wires?
My 77 came to me much as other old pickups have come to me, with the original 1977 plug wires still on the truck. printed right on the wires "1977"
if you popped the hood at night in the dark with the engine runng it looked like a lighting storm in the engine compartment.
frickin sparks shooting all over the place from all the wires.
Old Apr 23, 2009 | 01:11 PM
ford_man's Avatar
ford_man
it is a new cap and rotor, and wire set, when using the vacume gauge what am i looking for will there not be any vacume at all or will it be really low.
also when it spudders it is like i lose all power just when i shift into forth gear, in 3rd and 2nd gear it really wants to go, i have had someone say that it could be 4th gear is out well it just started doing it when i put a new eldebrock 500 on had a 390 holley on before that and it didn't do it.
thanks for all the help guys
