Any E4od experts??
Old Apr 22, 2009 | 09:17 PM
aljen466's Avatar
aljen466
Any E4od experts??
I had a couple questions regarding my e4od, hopefully someone who has more experience can help. When the truck is in neutral, should you be able to rotate the output shaft easily? I'm able to rotate the shaft clockwise with some resistance, but if I try to rotate it the other way there is quite a bit of resistance before it moves. Actually, it is the same in all gears, except for park. Is this normal? Thanks for any help.
Old Apr 23, 2009 | 06:50 AM
f350idi's Avatar
f350idi
Hi,
Yes this is normal, due to the low/ reverse one way clutch at the rear of the trans.
Regards f350idi
Old Apr 23, 2009 | 09:17 AM
aljen466's Avatar
aljen466
Thanks, I was hoping It was normal.
1994curtislowef250
20
Mar 10, 2013 08:00 PM
97FordF250HD
41
May 29, 2012 12:44 AM
golfpro1592
Nov 17, 2010 08:33 PM
Hogbrains
1997 - 2003 F150
Nov 25, 2005 09:39 PM
waltmoe
Dec 26, 2001 06:56 PM
