wheel adapters
Old Apr 22, 2009 | 05:46 PM
pipman76's Avatar
pipman76
wheel adapters
i was wondering if anyone has ever used those wheel adapters on your trucks so you could be able to use a 4 1/2 or 4 3/4 car bolt pattern wheel. ive seen in jegs adapters that bolt to ur hub and has the smaller pattern lugs
i want the american racing wheels 200s ,some people call these the coke bottle wheel ,they have to versions highly polished or the outer polish center painted gey which do u guys like better
Old Apr 22, 2009 | 06:00 PM
Stephen67's Avatar
Stephen67
As far as finish, depends on the rest of your car really. The grey and polished is more of a vintage race look, the polished is more of a bling look. All depends on what you're going for, I like them both.
I'm surprised they don't come in a stock size for the f-100s...
Old Apr 23, 2009 | 12:59 AM
Herbiehusker's Avatar
Herbiehusker
I have 1 1/2" wheel adapters on my truck. 5 x 4 1/2". I really like the stance that the 1 1/2" gives the rear...really fills the wheel well.
Old Apr 23, 2009 | 01:26 AM
Julies Cool F1's Avatar
Julies Cool F1
I also use wheel adaptors in the front. I have a 60's vintage Big Ford Car 9 3/8 rear end in my truck and wanted to bring the stock front end down to 4.5 x5 as well.
They work great - but a word of CAUTION.
They are normally made out of aluminum. If you have those little mounds on your drums around where the lug nuts go or any high spots, you will have to retighten those adaptors regularly (after 2 miles of driving a couple of times then about every 40 miles) for the first 200 miles they are on the truck.
Here's why, As you use them, the high spots on the steel drums will slowly eat and embed themselves into the aluminum - which is fine, but it allows the to fit closer to the drums and thus they loosen up under the lug nuts. Left loose it takes about 5 miles of driving before the lug nuts have backed off completely.
I actually lost my front left tire/wheel/adaptor once because of this. VERY scary! I had just pulled off the freeway and went to brake and turn at the same time. The truck turned alright, about 3 feet and the wheel kept right on going straight! And that's a very effective way to kill someone.
Here is the link to "The Lug Nut KIng" who sells the ones I have:
Lugnutking
Good luck!
Old Apr 23, 2009 | 01:58 AM
Herbiehusker
I forgot, I bought mine from ezaccessory.com
Old Jul 16, 2009 | 04:43 PM
Grumpy Gramps's Avatar
Grumpy Gramps
As far as the nubs on the drums go - just grind them flat. Once I did, the billet aluminum adapters tightened snug against the drum face. Why wait for a problem to develop?
Grumpy Gramps
Old Jul 17, 2009 | 01:03 AM
Julies Cool F1
Grumpy Gramps
20/20 hindsight.....Didn't realize they would do that - learned the hard way.
Old Jul 17, 2009 | 03:07 AM
55 f350's Avatar
55 f350
had a bad experience with 'em so if i wanna run a bolt pattern rim thats a different size i'll convert it . lost a wheel at 60 plus on a 67 427 impala that had a set of cragars from my then truck on for a show despit checking and rechecking and being ultra safety paranoid .................
Old Jul 17, 2009 | 05:27 AM
Lwlandy's Avatar
Lwlandy
When I first Got my 56 F100 it had wheel adaptors on it. PO had fitted some Ch$vy Rallye Wheels. (They didnt actually look to bad). When I stripped down the truck I found that two of the adaptors (Both fronts)only had 3 or the 5 studs still attached and the adaptors had actually split around the studs and that they had pulled through.
The adaptors fitted looked like they were made of a cast alluminum alloy of some sort. My advice would be if you have this type of adaptor, check on them regularly. Better to be safe than sorry.
Cheers
Lee
