Adding moldling to fender....
Old Apr 22, 2009 | 10:20 AM
berry1234's Avatar
berry1234
I found a replacement front fender for my smashed 78' Lariat. It's a F100 and has no molding originally installed. Is it a problem/hassle to install the holes or whatever I need to add my molding back on?
Old Apr 22, 2009 | 11:24 AM
Witty73's Avatar
Witty73
Before the days of the stud welding gun, body shops would drill holes and pop rivet the clips back on. If you are going to repaint, you can acutally weld the studs back on with a gun. Either way, its not too tough. Are you talking about the racetrack molding? or a wheel opening molding? If it is a wheel opening molding it is very simple to drill small holes and screw them on.
Old Apr 22, 2009 | 11:42 AM
berry1234's Avatar
berry1234
I need the racetrack molding and the molding at the top with the rubber insert.
Old Apr 22, 2009 | 04:09 PM
Jermafenser's Avatar
Jermafenser
Take it to a body shop and tell them you want it studded for moulding.
Carbon copy the old fender's location to the new one and mark them.
If the plastic wide body moulding inserts are still good, reuse them.
Old Apr 22, 2009 | 04:38 PM
berry1234's Avatar
berry1234
Perfect thanks.
jmbobs
2009 - 2014 F150
Feb 5, 2011 02:46 PM
Roelito78
Dec 23, 2009 05:11 PM
Ohio Ford Farm
Paint & Bodywork
Nov 9, 2009 09:04 PM
