O2 Sensor Questions
Old Aug 7, 2009 | 09:35 PM
  #31
Brad57's Avatar
Brad57
not map baro sorry
Old Aug 7, 2009 | 11:56 PM
  #32
wantaford's Avatar
wantaford
Originally Posted by Brad57
where is the baro sensor on a 95 F150 with a 5.0
Is it a Mass Air Flow Truck or a Speed Density setup? Cali emissions had the MAF's starting in 1995. The only real Barometric sensor would be a MAP sensor which the speed density systems used - I think those were mounted on the firewall. If you don't know what to look for go to a site like Autozone.com and look up the part - they will have an illustration for you.
Old Aug 8, 2009 | 05:34 PM
  #33
Brad57's Avatar
Brad57
its a maf truck but when i hook up a scan tool i get a reading for baro and it is way out of spec its the only sensor out of spec the maf is a new sensor
Old Aug 8, 2009 | 09:25 PM
  #34
wantaford's Avatar
wantaford
What code are you getting and what is the year and engine size of your truck?
Old Aug 16, 2009 | 03:34 PM
  #35
Brad57's Avatar
Brad57
its a 95 with a 5.0 i get random codes none for baro
Old Aug 16, 2009 | 04:45 PM
  #36
Conanski's Avatar
Conanski
As stated earlier in this thread the is no Baro or MAP sensor on MAF trucks, that figure is calculated by the computer using the MAF meter. The code you are getting means something different for these trucks so you'll have to post up the actual code you got.
fordpride
15
May 23, 2016 01:00 PM
wtroger
Modular V8 (4.6L, 5.4L)
Oct 21, 2015 03:01 PM
Achie
Oct 12, 2015 02:57 PM
fordpride
Jun 26, 2012 10:49 PM
chrism
Modular V10 (6.8l)
Mar 20, 2008 10:49 PM
