Sponsored by: Real Truck
Low range 2 wheel drive
Old Apr 21, 2009 | 01:59 PM
hammer65's Avatar
hammer65
Hey guys, I am ready to put in a switch to cut out the pulse relay for the ESOF when in low range. Does it matter which of the three wires I cut and run through the switch? Thanks to all Jim
Old Apr 21, 2009 | 02:25 PM
dchamberlain's Avatar
dchamberlain
Light blue with pink stripe is power when the key is in run. Grey with black stripe is grounded to engage the hubs, red is grounded to disengage the hubs.
I think I would break the engagement wire. That way the hubs would always attempt to disengage, regardless of your switch.
Old Apr 21, 2009 | 02:47 PM
hammer65's Avatar
hammer65
Thank you Dchamberlain: I appreciate that very much. Thanks for the wiring diagram.
Jim
Old Apr 21, 2009 | 04:21 PM
1975StroppeBaja's Avatar
1975StroppeBaja
subscribed
I think I'm going to do this at some point as well.
Good info dchamberlain! I tried to rep you but I gotta spread it around some first.
Old Apr 22, 2009 | 09:02 AM
elee3's Avatar
elee3
Thanks for the diagram dchamberain. Reps to you.
Do you happen to know where the ESOF solenoid is located?
Old Apr 22, 2009 | 09:05 AM
dchamberlain
Passenger side firewall, above the vacuum reservoir. It's a small unit with a 3 wire connector and two vacuum hoses. I have a picture around here somewhere, I'll see if I can find it.
Edit: Didn't have one, so I went and took one.
Old Apr 22, 2009 | 10:57 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If you don't want to go through the trouble of doing the switch thingy, you can always just unplug the connection on the sensor and it will not send the pulse to lock the hubs. This is what I do when I have to back a trailer up an incline. I don't do it much, so no need for the switch for me.
Old Apr 22, 2009 | 11:45 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Dave, are you sure you want to cut just the engagement side of things? A low-vacuum short pulse (20 seconds) is still applied for disengage, and I'd be worried that if the hubs are free-moving enough that they may lock instead of staying disengaged.
I had a situation once with my '01 that one of the hubs was working opposite, in that it was locked when I was in 2-wheel drive, and UNLOCKED when in 4-wheel drive.
I had to shut the truck down with the **** in 4x4, turn it to 4x2 with the key off, and restart, and it cleared up.
So, wouldn't it be best to cut the common and never have to worry about it?
Old Apr 22, 2009 | 03:52 PM
dchamberlain
I think you're right, upon further thought. The low vacuum pulse will hold the hubs locked until it releases. So it would be best to break the center power wire. Given that, if one were wanting to use upfitter switches, one could find that wire at the CJB, unhook it and hook it to an upfitter. Leave the switch on for normal operation, off for 2WD only operation. Or, use a relay for the opposite, but it could all be done in the cab, I would think. If you could find the right wire in the cab.
Edit: OK, this probably wouldn't work either, since F2.27 is one of the main switched power feeds and probably runs quite a few things other than the PVH solenoid. Now, you could still run a wire from an upfitter switch, into the engine bay, and either hook it directly to the center PVH solenoid wire and operate it like I described first, of use a relay to get an opposite result. If that makes any sense.
Old Oct 18, 2009 | 01:41 PM
WestxSRT10's Avatar
WestxSRT10
I'm wanting to do this low 2 wd switch to my 2008. I've located the relay and vaccum piping near the top back side of the radatior. I'm still not sure what to do.
Old Oct 18, 2009 | 05:06 PM
hammer65's Avatar
hammer65
I cut the red wire and routed through the switch. Works good for me. Jim
Old Oct 18, 2009 | 07:55 PM
74baja's Avatar
74baja
Art, are you saying to unplug the plug that is circled in red? I can think of a few really good situations for that... to get the TC locked up at lower speeds to reduce tranny temp.
Old Oct 18, 2009 | 08:43 PM
1975StroppeBaja
I'm glad this thread got bumped... I've finally spread it around enough to send the reps.
I still haven't got around to this mod yet... its on the list though.
Old Oct 19, 2009 | 01:40 PM
WestxSRT10's Avatar
WestxSRT10
I don't have a red wire...iI have 3 wires going to the relay- Brn/wht, Yel/gry, Blue/yel.
Old Oct 20, 2009 | 03:10 AM
TexasRebel's Avatar
TexasRebel
hmm
that 'L' on my shifter is so handy
