Technical discussion point... HPX line
Old Apr 21, 2009 | 07:48 PM
  #31
danskool's Avatar
danskool
Go Bills !
I was looking at it when i put on the HPX.. My first through is nothing moves through it. The tubing acts as just an accumulator when the shock of the injectors close/open. I looked up the hoses and the hoses are the same length. Could be wrong, just my initial thought when i installed it. I kind of just think that is just sits there and bounces around and very little movement happens , if any, seeing that it is fed at a high rate from the equal length/ dia.size hoses. Just a thought. And it would be interesting to set something up to see it in action.
Old Apr 21, 2009 | 07:52 PM
  #32
Mark Buzzard's Avatar
Mark Buzzard
Just a thought but shouldn't the oil lines in each head retain their prime after engine shut down. If this weren't the case air would be pumped into the injectors and I would guess lead to prmature failure or a no start condition.so it stands to reason the HPX would also retain a solid prime, thus no vapor. I am new to this mod and haven't done it myself yet but it sound like it does smooth out the engine which leads me to believe there is some fluid flow in the HPX. Just thinking out lod.
Old Apr 21, 2009 | 07:55 PM
  #33
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Wellllll there is one way to solve this... Is there a clear material that can withstand those pressures and temperature? May be time for a special made piece to view exactly what does happen... thinking outloud also but this did cross my mind
Old Apr 21, 2009 | 08:01 PM
  #34
Izzy351's Avatar
Izzy351
You need to invent transparent aluminum...
Old Apr 21, 2009 | 08:04 PM
  #35
danskool's Avatar
danskool
Go Bills !
A thought.. Take the HPX off. Fill the bent center portion with AFT. Reinstall. Run for a bit. Pull it off and dump.. If any red ATF still there. Then no movement. Can it be that simple?
Old Apr 21, 2009 | 08:09 PM
  #36
Izzy351's Avatar
Izzy351
I would wait until you have an oil change due and use FRESH oil and look for it in there after running for a couple minutes (idle). Yes, something like that would work, but it will be difficult installing without spilling a lot of it out would be tough. Of course, the fact that it's actully FULL after a minute or two of idling should be telling as well...
I really think y'all are over-thinking this. There is flow in the HPX, just like there's flow through the entire HPOP system....
Old Apr 21, 2009 | 08:12 PM
  #37
clux's Avatar
clux
Lets think about this logically-- the line is basically shaped something like a M.
If there is no movement of oil through the line......then there would be a static air bubble in the middle of the line that will stay there. when you start the engine, the air would compress down to almost nothing and almost fill the crossover with oil because of oil pressure, but when you shut it down, the air would expand and push the oil back out.
So even if there was no flow across the heads (and there is), there still wouldn't be static oil in the HPX long term.
Next question.
Old Apr 21, 2009 | 08:14 PM
  #38
F350-6's Avatar
F350-6
It should retain it's prime, and there should not be any vapor in the line, but when installing the line, you introduce some air/vapor into the system. Since the oil that enters the heads (& HPX) can only escape by exiting through the injectors, the question is, will the oil transfer from one head to the other, or will it just get stuck between the heads, along with whatever contaminants may be present.
Sounds good in theory, but with no air bubbles, will you be able to tell the oil is moving, or will it just look like a solid black line?
I'd guess there is a good possibility that some amount of ATF would mix with the oil to give it a tint. Unless you're talking about taking a look after 20k miles, an inspection after a short run may not be that useful.
Old Apr 21, 2009 | 08:15 PM
  #39
zx250's Avatar
zx250
Of the next Riffraff East
My thinking is somewhat simple, but it both rails are equal enough if pressure that the HPX would just be a buffer, then it wouldn't be needed. If any pressure differance is there, oil will flow to the lower side pressure, thus trying to balance the pressure. I betting there is pretty good flow from driver to passanger side.
Old Apr 21, 2009 | 08:26 PM
  #40
F350-6's Avatar
F350-6
Next question.
I'm not saying you're wrong, but your example assumes a large air bubble. What if there was oil exchange in the outer 4" or more of the line, and the stagnant oil (and any small air bubble) remained trapped in the center? For the sake of argument, let's say the HPO system has a temporary shortage of oil on the drivers side with the 6 then 8 firing, are you sure the 7 then 3 does not send a similar amount of oil back toward the passenger side? If so, how much oil are we talking about? Is it enough volume to clear the line, or just take some oil from each edge of the line?
This mods been out far too long for me to say there's anything wrong with it. I just enjoy these types of discussions. Understanding how thins work make them a lot easier to fix.
Old Apr 21, 2009 | 08:38 PM
  #41
CSIPSD's Avatar
CSIPSD
Can you say over thinking... LOL... There is always oil flow thru the heads... that hose will empty and fill it self several times a minute with fresh oil...
Old Apr 21, 2009 | 08:42 PM
  #42
clux's Avatar
clux
Unless the line is pre-filled with oil before installation, there will be an air bubble large enough to completely fill the line at atmospheric pressure when it is installed. For any of that air to be pushed out either side would indicate net flow.
In addition, every time I have pulled my HPX, it has been full of oil. Where did the air go that was in it when I installed it?
I've head some goofy things, but I've never heard that you need to pre-fill the HPX line.
Old Apr 21, 2009 | 08:43 PM
  #43
F350-6's Avatar
F350-6
Does the drivers side really require that much additional oil Joe? You'd almost think if the oil moved that well at over 2,000 psi, then you would notice some performance issues without the HPX.
Old Apr 21, 2009 | 08:46 PM
  #44
F250_'s Avatar
F250_
I agree fully, and I don't think anyone here would argue with you about this, but it is not the question at hand.
What is it that makes you so sure about that? I, too, believe that there is oil "movement", but not having factual flow data makes our opinions about this just that - opinions and varying degrees of educated speculation. I'm NOT saying your wrong, mind you... just that we have no real design or measured data to substantiate our suspicions.
... For the sake of argument, let's say the HPO system has a temporary shortage of oil on the drivers side with the 6 then 8 firing, are you sure the 7 then 3 does not send a similar amount of oil back toward the passenger side? If so, how much oil are we talking about? Is it enough volume to clear the line, or just take some oil from each edge of the line?.
Chris... you're doing an excellent job of fleshing out my thought process in all regards.
This mods been out far too long for me to say there's anything wrong with it. I just enjoy these types of discussions. Understanding how things work make them a lot easier to fix.
Here here!!
Old Apr 21, 2009 | 08:51 PM
  #45
beanhead6D5's Avatar
beanhead6D5
Pete,are you loking for witch way the oil flows though the HPX line?
I going back and reread you first question.
