Modular V10 (6.8l)
Iac valve
Old Apr 21, 2009 | 12:28 AM
44magnum's Avatar
44magnum
Iac valve
Will a bad iac valve cause a high idle after start up on hot engine.At start up it runs at 2000 rpm then creeps down to 1000 rpms and holds. 2001 f250 v10
Old Apr 21, 2009 | 02:00 AM
Monsta's Avatar
Monsta
Sit. Stay.
Usually a bad IAC manifests itself opposite of your symptoms.
Old Apr 21, 2009 | 08:33 AM
rlh68050's Avatar
rlh68050
Yes, it can. Do this test. Unplug the IAC electrical connector with the engine running at idle. The engine should stall. If is doesn't the IAC is sticking. Check for vacuum leaks otherwise.
chris3075
1983 - 2012 Ranger & B-Series
Feb 13, 2013 08:49 PM
britt
Modular V10 (6.8l)
Sep 2, 2012 06:27 PM
LI250
Oct 15, 2011 05:33 PM
mrossirr
1997 - 2003 F150
Dec 29, 2006 11:40 AM
ghkramer
Modular V10 (6.8l)
Dec 5, 2005 12:58 AM
