2 70 f100 problems
Old Apr 20, 2009 | 10:08 PM
Doc In Chatt's Avatar
Doc In Chatt
2 70 f100 problems
Working bugs out of my f100.
Speedo is 10 mph slow (60=50)
Bad vibration from 62 to 70 mph.
Swapped drive shafts with new u joints, problems still there.
302, c4, short bed with one piece drive shaft.
Any Ideas helpful.
Old Apr 21, 2009 | 12:04 AM
bmuhlbach's Avatar
bmuhlbach
need to pull out your speed-o gear and see how many teeth it has i would go with one with 2 less teeth.
Old Apr 21, 2009 | 09:15 AM
seafire's Avatar
seafire
71 problems
Have you balanced all four tires and wheels? If not, look for bent wheels when you have it done. Also, you may have a bearing problem too. I had the same problem on my 67 mustang, just about the same speed. I had the tranny rebuilt this past year, now the vibrations is gone. Just my two cents worth
Old Apr 21, 2009 | 06:19 PM
71'3604speed's Avatar
71'3604speed
rear wheel bearings
Old Apr 21, 2009 | 07:00 PM
seafire's Avatar
seafire
It depends on where you feel the vibration. If it is your seat, check the rear wheel bearing, if the steering wheel is vibrating, then it check the front.
Old Apr 21, 2009 | 07:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford's plastic speedo DRIVEN gears (on the end of the cable) can be plus or minus 7-10 MPH.
If the speedo reads 10 MPH too slow, take away one tooth. If you take away two teeth, the speedo will read too fast.
The gears are all still available, the most expensive is: $3.47.
Vibration: Look for a broken rear spring: If a leaf breaks, the entire spring pack will shift over to one side taking the rear axle along with it.
This will cause a vibration and dog-tracking.
Dog-tracking: Ever follow directly behind a vehicle and be able to see ALL four tires instead of the usual two?
That's caused by a broken rear spring.
Old Apr 22, 2009 | 04:37 AM
starmilt's Avatar
starmilt
If you feel it in your steering wheel check front end components including kingpins.
Old Apr 22, 2009 | 08:22 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Doc In Chatt
Welcome to ( FTE ) !
I think that you should make sure you have the Tires in the ( Size ) that you plan on running
,Low Profile, or Tall Tires will change your SpeedO reading, just make sure before buying
Parts or fixing the Problem, that this Problem may (REAPEAR) after a simple tire change!
Wally Womack
Last edited by Pro-Street/StateTK; Apr 22, 2009 at 08:24 AM. Reason: watching my Ps and Qs
Old Apr 22, 2009 | 01:46 PM
Danger_Dave's Avatar
Danger_Dave
when you serviced the driveshaft did you remember to put it back the same way it was? this can affect balancing if you do not mark it with chalk and if you installed it 90 degrees off in relation to the yolk for example. er um, the problem was happening before you even touched the driveshaft? nevermind
Old Apr 23, 2009 | 05:24 AM
Doc In Chatt
Found most of the vibration was 2 out of balance tires.
Going to go back over the motor and trans mounts and everything else.
Got it from a guy that let a chevy driver install the motor and trans.
He pitched the 80,000 aod in the dumpster because he didn't know how to hook up the 3 wires coming out of it and put in a points distributer but forgot to tighten all transmission bolts.
Found that the hard way by loosing the starter on the interstate in Atlanta.
Old Apr 25, 2009 | 10:37 PM
orich's Avatar
orich
Sounds like that guy had a great beer drinking day, working on that vehicle..
I've never done that or have, I not going to say and more..
orich
