electric fuel pump?
Old Apr 20, 2009 | 08:54 PM
dgraf961ton's Avatar
dgraf961ton
electric fuel pump?
I am so tired of these fuel leaks and the valley of diesel fuel! What is the best and cheapest way to convert to electric and get rid of the filter in the valley. I don't want a hack job but also don't care about making 600 horsepower.........well just not right now. I have seen the cpr kit and it looks great but for $1300 its a little....no a lot of dough. Anyone know of a better way and have a list of part numbers to do it. Its got to be reliable..no bailing wire and duct tap
Old Apr 20, 2009 | 09:02 PM
Gobstopper909's Avatar
Gobstopper909
heres a good writeup http://www.powerstrokenation.com/for...ht=fuel+system
Old Apr 20, 2009 | 09:35 PM
oldbird1965's Avatar
oldbird1965
That's why I went electric. I bought my kit from Swamp's but I don't recommend his products. Zero customer service, a jerk to try and work with once he has your money. I would go with beansdieselperformance.com. Heck of a nice guy.
Old Apr 20, 2009 | 10:22 PM
dgraf961ton
I will try beans does he offer a whole kit at a reasonable price? I looked at the above powerstrokenation link and am now super confused. I really like the idea of ford or IH parts and keeping it as simple as I can. I know for sure I don't want filters and seperators hanging below my frame rails. I have done many GM fuel injection swaps on other projects but this looks more confusing. I know on gas f.i. motors a fuel pump that is not in the tank is a huge no no as it gets to hot and does not last, must not be the case on a diesel. I just want simple and no codes or computer issues.
Old Apr 20, 2009 | 10:26 PM
Gobstopper909
im sorry about that. when you said you wanted a cheap system, i automatically assumed you leaning towards diy.
Old Apr 20, 2009 | 11:45 PM
dgraf961ton
No need to be sorry that is what I ment, just never thought it could be so confusing, kind of like to much information. This is something I want to do my self but would love a true complete list of part #'s and maybe a step by step process. Some were saying you need to modify the pick ups in the tanks and others said no. The wiring thing is a little rough to as I don't want the fuel pump on as soon as the key is on and I like the idea of the inertia switch for safty. I surely don't want to be throwing codes all the time. the most I would ever do is stage one injectors and a some programing so reliability is the most important thing. This is something I want to prepare for so the truck is not down for a long time.
Old Apr 21, 2009 | 07:07 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
IMO, the factory fuel system works great. Yes, electric is probably better, but if you're not after obscene horsepower, want Ford parts, want it reliable and easy to get parts for if you have to, and don't want a total DIY figure it out yourself system then just stick with the stock stuff.
If you have leaks, you need to fix the leaks. I've had many OBS trucks and have replaced many fuel pumps and filter housing hoses as preventative maintenance. I do not and have not ever had any fuel leaks. $100+- for new pump, fuel hoses and clamps, and keep the easy-to-get-to filter for changes and water draining.
Sure it's easier to work on without that stuff in the valley, but for a basically stock truck I see nothing at all wrong with the stock fuel system.
That link above is an excellent link. That system is about as simple as you can get if you want to get rid of the factory set-up.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 21, 2009 | 07:17 AM
KevinC.'s Avatar
KevinC.
Jim has a very good point. But if you still want electric fuel, I can PM a complete part list. I did my entire conversion DIY, right down to the inertia switch, and it was around 600.00. The most expensive part was all the fittings!! Once you take a step back and look at the fuel system, it is very simple. And no need to modify tank pick ups.
Old Apr 21, 2009 | 07:34 AM
Welk49's Avatar
Welk49
where do you get the fittings to for the heads to connect your fuel lines into? I heard some people were getting them from Diesel Innovations. Any ideas? About have everything I need to start my Electric System
Old Apr 21, 2009 | 09:11 AM
Neal 97 250's Avatar
Neal 97 250
I second the Beans system. That is the one I will install when I go Elec.
Old Apr 21, 2009 | 07:03 PM
Welk49's Avatar
Welk49
well just got my Filters, and ordered the FPR, still looking to find a pump at a good price. Might stop at the boneyard and see if there's anything there. Hope to get it all on soon.
Old Apr 22, 2009 | 07:24 AM
KevinC.'s Avatar
KevinC.
I got a SD pump from advance auto. 147.00 from the website. I wouldnt trust a used pump, could leave you stranded. As for the feed lines, I used a tubing cutter and cut off the banjo fittting. Spliced my lines onto the stock lines.
Old Apr 22, 2009 | 07:32 AM
Welk49's Avatar
Welk49
yeah after doing some research I think I am just going to order a Walboro pump, heard a lot of good things about them. Should have less than 500 in it when I am done.
Old Apr 22, 2009 | 08:29 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
DI has a great price on those fittings. But David will even tell you he made 600+ hp on the stock fuel lines.
there's no real need to go with those custom fittings, just splice onto the existing lines as noted above.
__________________
Old Apr 22, 2009 | 12:50 PM
Welk49's Avatar
Welk49
Thanks, now I just need to find a diagram on how to wire the system. Looked at the thread on Powerstroke Nation, but it doesn't tell you much
