540 CCA battery?
Old Apr 20, 2009 | 08:12 PM
brown 4x4's Avatar
brown 4x4
540 CCA battery?
I posted in another thread about how the battery seemed way smaller in 09. I serviced one again today and right on top it says 540 CCA. That seems a little small to me. I think every 08 and older I've seen has 800+. Is there an option for something bigger?
Old Apr 20, 2009 | 09:14 PM
Bsimmer3000's Avatar
Bsimmer3000
Doe's your truck have trouble starting? Reason being is we had some stupidly cold days here and it had no problem at all. Could be another issue and not your batt.
Old Apr 20, 2009 | 09:33 PM
brown 4x4's Avatar
brown 4x4
It's not had any problems starting that I know of (it's not my truck). I was just curious why Ford decided to downsize.
Old Apr 20, 2009 | 10:59 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
did it have the 4.6 2v in it?
that motor doesn't need alot CCA...it is the Mustang motor after all
Old Apr 20, 2009 | 11:41 PM
broncobran68's Avatar
broncobran68
The 5.4s have the 540cca too. Or at least mine does.
Old Apr 21, 2009 | 01:35 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
wow
that just seems so...inadequate. Wonder what the reasoning is behind that one?
Old Apr 21, 2009 | 07:26 AM
Bsimmer3000
I dont understand why it's ment to be larger? I could understand if the trucks had trouble starting in cold climates but 500+CCA shouldnt have any problem starting any 5.4 in 99.9% of climates.
Old Apr 21, 2009 | 07:52 AM
ChargersFanInCO's Avatar
ChargersFanInCO
my first 08 and my second one BOTH came with the 540cca. My first one died with no warning, and got replaced with the biggest one that would fit in the box. My second 08 got the battery replaced the first Saturday I had her. That 540 isn't enough for a well equipped truck.
Old Apr 21, 2009 | 10:58 AM
04XLTRUNNER's Avatar
04XLTRUNNER
i took that battery out and put the optima red top in out of my 05 that got wrecked.
Old Apr 21, 2009 | 11:14 AM
v_tach's Avatar
v_tach
Why would you replace a perfectly good battery? Why not use it for it's useful life then replace it with your choice?
Old Apr 21, 2009 | 11:22 AM
04XLTRUNNER
personal preference. just knowing that you have the power to start/run whatever you need in your truck without straining the alternator and battery.
Old Apr 21, 2009 | 11:29 AM
Bsimmer3000
So is it going to be better for my engine if i put a bigger batt in?
Old Apr 21, 2009 | 11:33 AM
04XLTRUNNER
well it wont hurt it. it really just depend on what your planning to do, running aux lights, winches, radio system, etc... stuff like that, then yeah i would go with a higher output battery. for stock, it would be fine.
Old Apr 21, 2009 | 02:01 PM
v_tach's Avatar
v_tach
No. If your battery is in good operating condition, there is no reason to replace it. High duty conditions may shorten the life expectancy of the battery but replacing it prematurely offers no benefit other than lightening your wallet. Extreme cold, running lots of off-road lights frequently, or running high power audio amplifiers are some of the more common high duty conditions that come to mind.
Old Apr 21, 2009 | 02:06 PM
Bsimmer3000
ohhhh good good. Would rather spend the money somewhere else.
