iac
Old Apr 20, 2009 | 06:58 PM
big64's Avatar
big64
iac
before i cleaned the iac when i unpluged it the truck would die. now that it is cleaned when i unplug it the idle is where it should be,when i plug it back in the idle jumps back up.does it sound like the iac is bad or something else.i cleand the tb also it still wants to stay open a little when i hit the acc pedal.88f250 with 302 manual trans. thanks
Old Apr 20, 2009 | 07:16 PM
subford's Avatar
subford
You need to get your throttle working right before you play with IAC valve.
Until it snaps closed when you take your foot off it you will not be able to check anything else out.
revans9295
Feb 21, 2012 08:56 PM
JFlom77
Feb 23, 2010 01:00 AM
yardbird
Modular V8 (4.6L, 5.4L)
Mar 31, 2005 08:08 PM
Skidly
Mar 17, 2005 11:41 PM
jswalker145
16
Mar 8, 2004 10:48 PM
