GP 2 4 6 8 Circuit Fail??
Old Apr 20, 2009 | 04:25 PM
bkcowboss's Avatar
bkcowboss
Gentlemen,
Got a CEL on a 00 Excursion and the code alluded to the entire bank of glow plugs being out, but the truck starts and runs smooth even below freezing, it came back after resetting, any ideas?
Old Apr 20, 2009 | 05:32 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Any chance the truck is a California model?
Old Apr 20, 2009 | 07:33 PM
F350-6's Avatar
F350-6
You can ohm the glow plug wiring to see if you have any bad plugs, but if it starts fine in cold weather with no white smoke, then it sounds like you've got a bad GPCM for the entire drivers bank to be down at once. What exact codes did you get?
Old Apr 20, 2009 | 07:56 PM
bkcowboss's Avatar
bkcowboss
Ill have to check again I didn't write down the codes. So where is the GPCM, what does it do and how hard is it to replace,
I don't know if its a cali model, don't even know how to check
Old Apr 20, 2009 | 08:16 PM
F350-6's Avatar
F350-6
The CA models came with a GPCM instead of a GPR. All of the Ex's also came with a GPCM. Joe forgot this part and was trying to make sure you had one before saying that sounded like you're problem. The GPCM is a rectangular box over near the rear portion of the passenger side valve cover. It has 2 large plugs going to it. It sits just behind a round relay (AIH). One of the plugs has wires that goes to the drivers side, the other goes to the passenger side. You can start with unplugging the connectors and see if there is any corrosion on the pins, cleaning things up, and seeing if that helps.
Old Apr 20, 2009 | 08:36 PM
bkcowboss's Avatar
bkcowboss
cool that helps alot, I will check it out and post the results that work
Old Apr 20, 2009 | 08:51 PM
PaysonPSD's Avatar
PaysonPSD
If you swap the two connectors on the GPCM and the same codes for GPs 2-4-6-8 come back then you have a bad GPCM. I doubt you have 4 bad GPs or a connector or harness that is affecting all 4 GPs. A bad GPCM will show one whole back or the other bad.
Edit: If you swap them don't forget to swap the back.
Old Apr 21, 2009 | 08:47 PM
bkcowboss's Avatar
bkcowboss
good tip payson, I will give it a shot, the next question I have is do I have to replace it? The system seems to work fine....
Old Apr 21, 2009 | 09:15 PM
PaysonPSD's Avatar
PaysonPSD
It you are sure the GPCM is heating the 2-4-6-8 GPs there would be no reason to replace it but if you have trouble starting during the next cold spell you will know where to look.
Old Apr 21, 2009 | 09:33 PM
F350-6's Avatar
F350-6
Unless he has a vehicle inspection coming up. They typically won't pass an inspection with the CEL on.
Old Apr 22, 2009 | 12:39 AM
PaysonPSD's Avatar
PaysonPSD
I would never have thought about that. Since I moved to Gila Couty Arizona 8 years ago I have never had to go through one of those dreaded vehicle inspections.
Old Apr 22, 2009 | 08:07 AM
bkcowboss's Avatar
bkcowboss
No vehicle inspections here but my father in law is one of those guys that will replace it if bad. He has to have things "working" right.
Old Apr 22, 2009 | 08:08 AM
bkcowboss's Avatar
bkcowboss
F-350 and Payson, attempted to rep ya but I have to spread some around.....
Old Apr 22, 2009 | 09:27 AM
PaysonPSD's Avatar
PaysonPSD
I would change it if there is a constant CEL. How would you know if there were a new problemm without always reading codes.
Thanks for the thought.
Old Apr 22, 2009 | 10:54 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
From the time you mentioned that a whole bank of plugs had gone out, my first thought was GPCM.
All Excursions equipped with the 7.3 are California trucks, why Ford did that is beyond me, but who am I to question them...
It's on the passenger side of the engine and as F350-6 said, it has a Black and Green connector going to it: two plugs, two bolts, ten minutes, and you're back on the road. You can get the part off flea-bay for a reasonable price as I'm sure the dealer may want your first born.
