f250 solid axle swap
Old Apr 20, 2009 | 11:12 AM
jleal_21's Avatar
jleal_21
would this operation be a bolt on application or will some fabrication and welding be needed? this would be having the donor truck instead of buying piece by piece. what year models would work for this?
Old Apr 20, 2009 | 11:56 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
simple bolt on. at least mid 80's to '97 dana 60 will do. i think '94-'97 have less desirable ball joints where the earlier 60's have kingpins. that won't effect the swap operaion though.
Old Apr 20, 2009 | 04:33 PM
Gobstopper909's Avatar
Gobstopper909
x2 everything is bolt on, except youll need diff brake lines, and i heard somewhere that youll have to switch leafs? somthing about the ttb leafs are angled and they will break if you go to a solid axle.
Old Apr 20, 2009 | 04:48 PM
96P_Stroke4x4
Smokin'
nothing wrong with using ttb leafs, except it will be a little harsher ride. the ttb springs are actually a little stiffer to withstand the twisting. if you have a donor truck, you might as well take the springs. if you leave the springs attached to the axle, you will just have to worry about the 4 spring eye bolts, steering connection, track bar, and maybe sway bar connections. it's a lot easier than it may seem.
Old Apr 20, 2009 | 07:42 PM
joe_13894's Avatar
joe_13894
The brakes were beefed up in MY 95. If you get a 94 or older axle, the front brakes aren't as strong.
Old Apr 20, 2009 | 08:56 PM
Gobstopper909
probably just
a fella at a swap meet got me scared about using my ttb springs. i knew they were thicker than the 1 ton's but thanks for the info
Old Apr 21, 2009 | 05:19 PM
F250Growler's Avatar
F250Growler
what does everyone do with their left over ttb after the swap? is it desired by anyone else?
Old Apr 21, 2009 | 05:26 PM
joe_13894's Avatar
joe_13894
I see them on Craigslist quite often for $200 to $250.
I have no idea what they are used for beyond replacing collision damaged axles.
The hubs can be stripped for some $$$
Old Apr 21, 2009 | 05:56 PM
F250Growler
what are the advantages to having a dana 60 front axle over the ttb?
Old Apr 21, 2009 | 09:02 PM
joe_13894's Avatar
joe_13894
To align a TTB, the shop better know what they are doing. The bushings all have to be in decent shape or it will tear up tires. The alignment is dependent on load so if you have huge load swings like putting on a plow, they won't stay alligned. Lift kits are even more problematic.
The D60 doesn't have any of these issues.
The D50 has 1350 U-joints which will pop around 2,200 ft-lbs per side. The D60 has 1410 U-joints that can take 2,700 ft-lbs per side. 2,200 ft-lbs is plenty to burn out stock tires on bare pavement. But go stick big tires on it and you can blow U-joints or other parts on a D50.
Old Apr 21, 2009 | 10:58 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Can you use one from a superduty? If not why? Are they less desirable because of the sealed axel bearings?
Old Apr 21, 2009 | 11:12 PM
BlueMule's Avatar
BlueMule
BINGO!
You can't service them and it cost a couple hundred per side to replace them.
And not all SouperDootys had D60's some had monobeam D50's
Old Apr 21, 2009 | 11:16 PM
coreylasalle's Avatar
coreylasalle
so king pins would be more desirable?
Old Apr 21, 2009 | 11:27 PM
BlueMule's Avatar
BlueMule
I thought so!
I bought a 94 balljoint axle and then sold it to buy the 86 kingpin that's under the truck.
Old Apr 22, 2009 | 12:15 AM
joe_13894's Avatar
joe_13894
Originally Posted by BlueMule
BINGO!
Only the DRW superdootys have D60's. The F350 SRW and the F250 have D50 monobeams.
FYI, the D50 monobeam guts are not interchangeable with the D50 TTB
