Help With 370-4v - 429/460 Swap !!
Old May 12, 2023 | 01:05 PM
  #31
GingerJimmy's Avatar
GingerJimmy
4th Gear
Originally Posted by garygnu
use the balancer and drive pulleys from the 460 ,see if the flex plate from the 460 looks the same as the 370 flex plate .you can buy thin shims to get the water pump pulley to line up with the crank pulley .for the alternator and power steer ,you might have to alter the brackets to move those things into alignment .
the flex plates are different. Two major differences are the depth or offset of the torque converter mounting surface and the amount of mounting hole for the torque converter. The 370 has 6 bolts vs the 460’s 4 for the C6
Old Jun 5, 2023 | 10:14 PM
  #32
garygnu's Avatar
garygnu
what transmission is in the truck ? will the converter from the donor car fit in the truck transmission ? you can use some shim /washer to install the converter .
Old Jul 12, 2024 | 09:39 PM
  #33
L8sleeper's Avatar
L8sleeper
1st Gear
Amazing thread! I hope more people see this (and yes I ain’t a bot.)
Hello Everyone! First off, amazing read. Hotwrench and 85, and others wow…..thank you for the knowledge/refresher for me on the 385’s. My Dad’s ‘75 F250 is an FE rig, but I did own a ‘78 (that I’m hopefully getting back next year) that had a ‘72 429 from a t-bird transplanted into it. Most of my questions are answered within the thread so I want to thank everyone of you for the information, both known and new and for keeping a thread very much alive over FIFTEEN YEARS! Thank you again!
Jim Akines
Oct 18, 2017 09:28 PM
Ryan Slater
Sep 7, 2017 02:31 PM
Ryan Slater
May 26, 2017 11:15 PM
Barrett Mills
13
Feb 15, 2017 12:21 PM
skd91
Large Truck
Sep 23, 2016 08:09 AM
