Hydro boost parts 1982 f-700 370-4v
Looking for a part number for the relay that powers the emergency secondary electric pump for the hydroboost. Also looking for the part number for the pressure switch. The relay is a 4 pin. 2 of the pins have wires soldered to them. The pressure switch is a 1 wire. Thanks
Check Rockauto - a quick scan shows that they have the Hydro-Max brake system parts, and some one wire brake switches - but you'll need to look at the photos to see if that's what you need. 1982 FORD F700 6.1L 370cid V8 Electrical-Switch & Relay Parts | RockAuto
Did you look at the site?
I said "brake switch" not the same as "brake light switch". At Rockauto their "brake switch" listing may be a "pressure switch", you need to look at the photos and part numbers.
I guess I'm not familiar with your setup. The hydro-boost systems I've seen have a pressurized chamber/canister to provide the emergency assist if engine dies. I'm not aware of an electric pump setup for the emergency assist (that would seem to be more problematic and would warrant a backup of its own ).
Your truck model is not covered in my Service Manual - maybe someone else has this info.
You might go ask in the Large Truck forum and see what people there say.
https://www.ford-trucks.com/forums/forum232/
Last Chance 55
07-19-2007 07:20 AM
doug51f1
22
12-17-2006 04:20 PM
quent
09-06-2004 08:11 PM
