Front axle shafts
Old Apr 19, 2009 | 08:17 PM
PJF150's Avatar
PJF150
Front axle shafts
Hi Guys
Wondering when im in 2wd,do the front axle shafts remain stationary?I went under my truck with the engine running&in 2wd,tried to rotate the shafts by hand&find them locked.Went to 4wd&locked as well.Im getting a little concerned if they are turning while driving while im in 2wd.I have had an issue with the integrated wheel ends sometimes banging in place when wet.I have done research on these bearings&wondering if there is damage?Should those shafts not move when in 2wd?
Ford has put out a TSB(Technical Service Bulletin)number 06-8-15 in the IWE&going to check this out further.Input would be appreciated,thanks...Pete
Old Apr 19, 2009 | 09:36 PM
Ford_Six's Avatar
Ford_Six
What's the vehicle? If it's a 97+ f150, or an IFS Ranger, it doesn't have lockout hubs. The CV shafts are splined, and bolt onto the wheel mount flanges, so they always are locked together.
Old Apr 20, 2009 | 04:59 AM
PJF150's Avatar
PJF150
Its an 05 F150 STX supercab
